Vixen 0.965 to 1.25" adapter list of compatible scopes
72 replies to this topic
#26 eric_zeiner
eric_zeiner
  • Loc: Perry, GA USA
Posted 02 January 2022 - 07:41 PM
If it's like other Cartons (excluding beginner models)  a Vixen should fit.
I don't remember ever seeing a 60/1200, did you mean 60/1000?
Yes, my mistake, I did mean 60/1000.  It isn't a beginners model and it will be here tomorrow.  If the Vixen adapter fits, I will be quite happy.
Edited by eric_zeiner, 02 January 2022 - 07:43 PM.
#27 Kasmos
Kasmos
  • Loc: So Cal
Posted 02 January 2022 - 09:47 PM
60mm Carton focusers
If it's like this:
Yes.
Look for the finder mounted on the focuser
If it's like this:
No.
Finder is mounted on the tube and it's cone shaped where it meets the tube like some Towas
I've seen some 60/1000mm Cartons with this type of focuser but they were Alt-Az models as was this 900mm.
Edited by Kasmos, 02 January 2022 - 09:49 PM.
  • eric_zeiner, Bomber Bob, walter a and 2 others like this
#28 Jon Isaacs
Posted 03 January 2022 - 02:06 AM
The Vixen Adapter does not fit the 60mm x 800mm Asahi-Pentax.  It's the right diameter but the wrong pitch.
#29 walter a
walter a
  • Loc: Prawda Manitoba Canada
Posted 03 January 2022 - 06:05 AM
Works on the crinkle and smooth finish polaroscopes, but I dont know the maker of these.
  • mdowns and Bomber Bob like this
#30 Senex Bibax
Senex Bibax
  • Loc: Ottawa, ON
Posted 03 January 2022 - 08:32 AM
I have one of those, the cover over the focuser pinion gear is marked <C.O.C.>, i.e. Carton. I confirm that the Vixen adapter fits as I have one.
  • Bomber Bob likes this
#31 eric_zeiner
eric_zeiner
Posted 03 January 2022 - 11:29 AM
If it's like this:
Yes.
If it's like this:
No.
Yes, according to the photos and the assembly diagrams of this scope, the finder is attached to the focuser.  It is supposed to be here today and I will know better then.  This scope is a Carton made Monolux 60/1000 and it is on an EQ mount so I should be good.  I will also know better what model Monolux it is.  It has C.O.C. Monolux printed on the cell.
Edited by eric_zeiner, 03 January 2022 - 11:31 AM.
#32 walter a
walter a
Posted 04 January 2022 - 05:51 AM
Works on the 152 and 304 power Tasco's.
#33 eric_zeiner
eric_zeiner
Posted 04 January 2022 - 11:49 AM
Well because of the inclement weather in the NE, my scope won't be here until tomorrow.  It came from Massachusetts and finally made it to Georgia early this morning.  I do hope that the Vixen adapter fits it.
#34 eric_zeiner
eric_zeiner
Posted 05 January 2022 - 03:29 PM
It does fit the C.O.C. Monolux 60/910.
  • mdowns and Universe XY like this
#35 geophilip06
geophilip06
Posted 05 January 2022 - 08:07 PM
Tasco 9VR
Jason saturn 324 (80/1200)
Aerolite  859 (Swift/COC) 60/910
Edited by geophilip06, 05 January 2022 - 08:08 PM.
  • mdowns and C140Cessna like this
#36 telesonic
telesonic
  • Loc: SW Idaho
Posted 06 January 2022 - 12:52 AM
Good topic LGM!
Does Not Fit:
I have an old Sears Discoverer 80mm f/15 (or Towa 339 by other nomenclature) and the Vixen 36.4 1.25 adapter does not fit the .965 drawtube on this scope. I don't have dimensions for the vb it uses at hand right now, but can get them.
Fits Fine: (with extension tubes)
My C-4.5 newtonian (Vixen) uses one of these adapters for the eyepiece, and also an extension tube - both 36.4 thread, and they fit just fine. Likewise with my Comet Catcher, same  threads as well.
T
#37 norvegicus
norvegicus
  • Loc: en route
Posted 18 February 2022 - 05:01 PM
Another option is a Baader 1508039 36.4mm to T-2 adapter ring, onto which you can add any T-2 threaded visual back, diagonal, or other accessory.
https://agenaastro.c...03-1508039.html
  • deSitter, GeneDiG, tturtle and 3 others like this
#38 deSitter
deSitter
    Still in Old School
Posted 18 February 2022 - 07:27 PM
Fits:
Sears 6344, 6345
Monolux 4380 (AO)
Daylite 60/910 (K)
To be checked - using the focuser on the AO 60/910 scopes (Tasco 7T, Monolux 4380 etc.) which screws into the tube, on the Tasco 10TE-5 and similar scopes - Sears 6339a, AO R-74, Scope 76/1200 etc. I seem to remember this works but that Tasco is buried and I'm not going to unearth it right now smile.gif
edit: CONFIRMED. https://www.cloudyni...4380/?p=7884710
This is the easy way to do 1.25" on these 76mm AO scopes!
-drl
Edited by deSitter, 18 February 2022 - 07:56 PM.
#39 semlin
semlin
Posted 18 February 2022 - 07:40 PM
i just ordered one of these just a few minutes ago after finally finding one for sale in canada
https://www.baader-p...2-part-11).html
notice it says t2 on the side.  i believe it is the baader t2 (female fit) helical eyepiece plus the t2/36.4 adapter you are listing for only $5 more than the helical focuser alone.
if correct, then the adapter is nearly free and you can use the helical eyepiece on any t2 threaded option.  which i intend to do with my rao r73 since i want one.
worse case i have a helical vixen vb.
  • tturtle and norvegicus like this
#40 norvegicus
norvegicus
  • Loc: en route
Posted 18 February 2022 - 08:01 PM
$52 at Agena , which is actually $4 cheaper than the T2 visual back / focuser by itself, but out of stock.
https://agenaastro.c...er-2408195.html
https://agenaastro.c...crofocuser.html
Edited by norvegicus, 18 February 2022 - 08:04 PM.
  • DouglasPaul likes this
#41 jkmccarthy
jkmccarthy
  • Loc: Los Angeles, California U.S.A.
Posted 19 February 2022 - 12:46 AM
It's a bummer because just 2 years ago, these were available from Japan for $15, now $25
https://www.ebay.com...rsAAOSwJ6NbwZyu
These are still a relatively inexpensive add-on (in quantity 1 or more than 1) to the parcel for any medium or large Zen-Market item that you [or someone you know* : - ] may soon be purchasing, since the size and weight of the #3720 adapter(s) are not likely to make any significant impact to the shipping cost you will be charged for a medium or large Zen-Market item parcel ....
https://zenmarket.jp...Code=B00140CEAE
Through Amazon-Japan, no need to fuss with auction bidding, or sellers with no prior sales feedback, etc.   Price quoted on the page above does not include Zen-Market's purchasing fee (a single charge of $3 total for Zen to purchase #3720(s) for you from Amazon-Japan, irrespective of the quantity you request) nor does it include the shipping cost within Japan from Amazon's warehouse to the Zen-Market warehouse (which cost me $5 total for quantity=3 recently).   YMMV.
       -- *Jim
Edited by jkmccarthy, 19 February 2022 - 12:47 AM.
  • norvegicus likes this
#42 semlin
semlin
Posted 24 February 2022 - 02:09 PM
this just arrived, and i confirm you get
1.  a removable vixen 36.4mm to t2 male/male adapter
2.  a helical focuser with a t2 female thread.  it has travel of about 1/2"
3.  brass compression ring 3 bolt 1.25" visual back.  not sure if this separates from the helical focuser but it looks like it does.
i am pretty happy with this set up.  i can use the adapter with a regular ebay compression fit visual back and put the helical focuser/vb where required.
  • deSitter, Pete W, Bomber Bob and 1 other like this
#43 norvegicus
norvegicus
  • Loc: en route
Posted 18 March 2022 - 06:32 PM
As of today Explore Scientific is selling the Vixen apapter.    I can't tell if they are actually in stock.
https://explorescien...6-4mm-to-31-7mm
Edited by norvegicus, 18 March 2022 - 06:32 PM.
#44 Lentini
Lentini
  • Loc: Alexandria, Virginia
Posted 26 September 2022 - 12:44 PM
Does fit Takahashi TS-65 and TS-80.
(But because of the single set screw on this, I far prefer either the Takahashi compression adapter or the three-screw low-profile Baader adapter.)
#45 Astrobril
Astrobril
  • Loc: The Netherlands
Posted 27 September 2022 - 02:25 AM
Fits on my HOC 50mm (Astro Optical T-8)!
https://www.cloudyni...ro-optical-t-8/
#46 MJB
MJB
Posted 03 October 2022 - 02:18 AM
Fits my 60/910 Eikow 6T-300
  • Soundboy121 likes this
#47 norvegicus
norvegicus
  • Loc: en route
Posted 03 October 2022 - 06:59 AM
Fits my Vixen 80M, both the drawtube and the weird factory diagonal that mounts with a 36.4mm thread and has a removable visual back with the same thread.
Edited by norvegicus, 03 October 2022 - 06:59 AM.
  • Skywatchr likes this
#48 C140Cessna
C140Cessna
  • Loc: SE/Mid-Michigan
Posted 28 April 2023 - 12:25 PM
Tasco 9VR
So, are you saying that it DOES fit the Jason 324 Saturn? I happen to have one of these that I am trying to get up and running...and I'd appreciate any help in getting to to use 1.25" eyepieces. Id like to avoid the hybrid diag is possible.
Thanks, Todd
#49 norvegicus
norvegicus
  • Loc: en route
Posted 28 April 2023 - 12:47 PM
Thanks, Todd
Hi Todd,
If the draw tube has a 36.4mm thread it will work.  Another option is a 36.4mm to M42 (T2) adapter and a T2 based visual back, for example:  https://agenaastro.c...03-1508039.html
Here is one that includes both parts:  https://agenaastro.c...er-2408195.html
Edited by norvegicus, 28 April 2023 - 12:48 PM.
#50 GeneDiG
GeneDiG
Posted 04 May 2023 - 08:54 AM
The Vixen adapter will fit the Tanzutsu and Vixen made Tasco 9VR/99VR/999VR family of short tube 60mm refractors. The Vixen adapter will NOT fit the Towa made Tasco 11T 4.5" Newtonian reflector. The Sears 6305A 60mm equatorial refractor made by Towa cannot use the Vixen adapter.
