Not exactly the Imaging X-ray Polarimetry Explorer, but it's the first astronomical polarimetry image for me
8 replies to this topic
#1 Organic Astrochemist
Posted 02 January 2022 - 11:02 PM
Recently, NASA launched the Imaging X-ray Polarimetry Explorer which, along with the JWST, has new and unique observing capabilities.
IXPE
More humbly, I have been struggling for over a year with my QHY550P camera with a polarization filter.
I finally learned enough Python (and about Windows 10) to enable me to create an image of the angle of polarization.
I used a celestron C90 piggybacking on my Atlas mount to capture this image of the Orion Nebula, in 360 seconds at 100 gain. I was using a V-band filter so no Hα.
The polanalyser code required some debugging and optimization, but it is able to demosaic the image into four channels, one for each polarization angel 0°, 45°, 90° and 135°. The values of four contiguous pixels are then used to calculate the degree of linear polarization and the angle of linear polarization. The code then converts the angle value into a color based on the following color wheel:
  • gregj888 likes this
#2 Organic Astrochemist
Posted 02 January 2022 - 11:24 PM
And here is the angle of polarization image
I didn't have time to properly calibrate the image with darks and flats, so that is certainly the next step. But as a proof-of-principle I think this is a success.  Whenever there are changes in intensity that are smaller than the four pixel scale, the values of polarization will be affected and this will generate erroneous values. The yellow blobs in the middle are the trapezium. In between the pink and the yellow pixels that run from the center to the top are the red pixels that correspond to 0° angle of polarization (I have to calibrate this too with the sky). Going counterclockwise the colors are red to yellow to green to blue to pink to red to yellow to green to cyan to blue to pink. In other words, the angle of polarization is symmetric around θ1 Orionis C, the brightest star in the trapezium which is primarily responsible for ionizing the nebula. This is consistent with the literature
  • gregj888 and mwr like this
#3 mwr
mwr
Posted 08 January 2022 - 08:23 AM
Really nice work! Can you give the degree of polarization as well? Is there a software available that allows to draw the polarization vectors (lenght=degree of polarization; direction=angle of polarization)?
#4 Organic Astrochemist
Posted 12 January 2022 - 03:31 PM
That is how they display the data in the paper I cited. Theoretically it should be doable in Python, but I'm not there yet. What I can do is use the color to show the angle and the intensity to show the degree of linear polarization. But there are some problems with astronomical images. The program must have predefined maximum values for each pixel so if I stack or saturate the stars it doesn't return the correct DoLP. So I still have some work to do. Here is an example with a terrestrial image.
Here is an image of a table with light reflecting off it.
Here is the degree of linear polarization DoLP
#5 Organic Astrochemist
Posted 12 January 2022 - 03:33 PM
Here is the angle of polarization for each group of four pixels AoLP
#6 Organic Astrochemist
Posted 12 January 2022 - 03:34 PM
And here is the angle of polarization, but scaled to the degree of polarization, which shows the color for the angle but the intensity is given by the degree of polarization,
This effectively has the same information as the graphic in that professional paper.
#7 Octans
Octans
Posted 12 January 2022 - 06:05 PM
One nice way to visualize this kind of data is to put it into HSV or HSL color, with polarization angle as the hue, degree of polarization as the saturation, and the intensity as the value/lightness. I think that may be roughly how the fairly famous Hubble picture of the Egg Nebula was constructed: https://hubblesite.o...1305-Image.html
Edited by Octans, 12 January 2022 - 06:08 PM.
#8 mwr
mwr
Posted 13 January 2022 - 05:07 AM
I can still vaguely remember a polarisation map of comet Neowise and have just found the corresponding page at the BAA:
https://britastro.or...15#comment-9015
https://britastro.or...29#comment-9029
"The polarisation functions in IRIS are used to produce the various maps."
May be you can give it a try. IRIS is available here: http://www.astrosurf...s-software.html
The tutorial describes the polarization analysis here: http://www.astrosurf...13/doc34_us.htm
#9 morsanimi
morsanimi
Posted 14 January 2022 - 02:43 PM
Maybe here, there could be sth of use.
https://github.com/a...plpy/issues/128
