What classic mounts are worth stalking?
46 replies to this topic
#26 Kasmos
Kasmos
  • Loc: So Cal
Posted 13 January 2022 - 09:30 PM
No I didn't. I did spend most of the time with the Aerolite optical tube mounted on it which
is very light and I almost always used the flex control rods when observing.
I really liked the aluminum legs with their twist locks, and extremely light and portable.
Robert
Yeah, the legs and the whole kit is super light (Hence Aero-lite?) and very attractive.
At first I wasn't sure about them, but I actually like the way they looked when I set it up and how the twist locks work.
But it seemed that the tripod would twist and flex with everything tight.
I'll have to give it another try.
Do you still have the white replacement?
#27 Kasmos
Kasmos
  • Loc: So Cal
Posted 13 January 2022 - 09:41 PM
Not the best photo, but I found this one (taken at night), of the Mayflower 806 cutdown (60/400mm) riding on the Unitron 114 mount.
Unitron 114s have a larger diameter tube than most other 60mms so a cardboard collar was used to fill the gap.
I need to make a permanent well made collar/adaptor so any of my 60s will fit and look better.
If the OPs goal is a small grab go Classic mount, it's probably the best option.
  • mdowns, Terra Nova, Bomber Bob and 1 other like this
#28 jkmccarthy
jkmccarthy
  • Loc: Los Angeles, California U.S.A.
Posted 13 January 2022 - 11:22 PM
Reading through all these replies, my summary reaction is "should have quit while we were ahead"(!) ... the original Vixen Polaris EQ makes the best alt-az (better than SP or GP) since in the alt-az mode suggested in post #2 and pictured in post #3, the R.A. (here azimuth) axis is centered over the tripod hub (which is not the case with the SP or GP).  A counterweight shaft and weight could even be added to put the center-of-mass over the tripod hub also.
Since the OP described the 60mm as a "project scope", perhaps a made-in-Japan classic mount is not essential, in which case the TeleVue Telepod (on a re-purposed photo tripod) or Panoramic (with dedicated tripod) might also be considered a capable contender ?  Beauty in Simplicity --- no slo-motion controls, but buttery smooth brass bushings with knobs making it easy to dial-in just the right amount of friction ... although paying *extra* attention to how the scope+cradle are balanced [not only along the telescope's optical axis, but also above vs. below the mount's elevation axis] will reward you with dividends out under the stars.
More suggestions offered and pictured here (see especially post #16):
https://www.cloudyni...c#entry10102206
       -- Jim
Edited by jkmccarthy, 13 January 2022 - 11:28 PM.
  • AstroKerr likes this
#29 clamchip
clamchip
  • Loc: Seattle
Posted 13 January 2022 - 11:26 PM
Yes I still have the white replacement, it has wood legs.
Robert
  • Kasmos likes this
#30 Terra Nova
Terra Nova
  • Loc: 39.07°N, 229m AMSL, USA
Posted 14 January 2022 - 07:15 AM
Any 60mm can benefit from a Unitron alt-az mount!
  • clamchip, icomet, mdowns and 4 others like this
#31 clamchip
clamchip
  • Loc: Seattle
Posted 14 January 2022 - 10:58 AM
What I like about the Unitron 60mm alt-az is you can use different size tube rings.
Here's mine with a lightweight 3 inch a Edmund f/15.
Robert
Edited by clamchip, 14 January 2022 - 11:00 AM.
#32 Kasmos
Kasmos
  • Loc: So Cal
Posted 14 January 2022 - 03:01 PM
I think everyone does have to keep in mind that the OP is talking about a modified Tasco 60mm zoom so I'm not sure how much the OP is willing to spend on a mount for it? Even the 114 mount (which I also recommend) usually goes for $100-$150 without legs and that's probably 3 to 5 times what those zooms go for.
That said, they are useful for other scopes you might have or someday aquire.
  • clamchip, DreamWeaver, mdowns and 3 others like this
#33 photoracer18
photoracer18
  • Loc: Martinsburg, WV
Posted 14 January 2022 - 04:35 PM
Here is a little alt-az mount that is interesting. The Borg AZM-100. I picked one up a few years ago and I can't seem to let it go.  Similar to the good mounts like the Unitron with dual tangent arms except it has electric slow-motion under the cover on both axis's. Dual speed hand-control with a small battery pack, comes in black or something like the old Vixen light green. Does not take up a lot of room in a backpack. Also comes in 2 version as the green one comes with a tripod (AZM-200) and the black is designed to use a photo-tripod (AZM-100). I have the black one.
Here is a link to the 3 page pdf manual on it, https://www.sciencec...ltaz/mmount.pdf
 It will carry up to an 80mm triplet or Fluorite doublet as I have used an FL-80S, a TMB 80 SS, and an AT80LE on it. It fits on any decent 3/8-16 thread photo tripod although I use a heavier Bogen 3021 or 3221W because that is what I have.
Edited by photoracer18, 14 January 2022 - 04:53 PM.
  • mdowns, Bomber Bob, Defenderslideguitar and 1 other like this
#34 Garyth64
Garyth64
  • Loc: SE Michigan
Posted 15 January 2022 - 09:20 AM
The following are examples of some very nice mounts, IMO.    They can be found on a variety of scopes, and had a few variations.
Mostly they were used on 60mm telescopes like the 7TE series, Space Scope, and many others.  They also came with an ATCO 1254 (80mmx 1200mm), but I think that long tube may have been too much for it.  But the mount seems find on a Selsi 247 (80mmx910mm).
-7TE-2
-ATCO 1254
-Selsi 247
These mounts have smooth dec and RA controls, and when equipped with a CD, they track pretty good too.
  • astro140, mdowns, Terra Nova and 3 others like this
#35 Terra Nova
Terra Nova
Posted 15 January 2022 - 12:02 PM
^Same mount as that for my Monolux 4380^
  • Garyth64 likes this
#36 TheWatcher
TheWatcher
  • Loc: Rochester, MN
Posted 15 January 2022 - 01:43 PM
Those scopes use objectives at f/7 or so (60/400mm) - the long tube is a consequence of the image-erecting lens train. I converted 3 such scopes to super-finders/side scopes with excellent results. You have to saw into the tube and install a new focuser in the sawed-off part.
-drl
I acquired this setup with the conversion started. The original tube and EP/erector/zoom are intact and a second sawed off tube is fitted with a plumbing parts focuser. I do have a focuser and diagonal to finish the conversion but still use the makeshift focuser.
Is there anything useful or interesting to be done with the internal components of these units? Make an EP and barlow? Educational props? Demonstrate fracturing glass? Does everyone just squirrel them away for "completeness of kit" should they ever put it up for sale?
Why are these zooms generally poor optically? Are the internal lenses not made by the same folks as the vaunted Japanese objectives?
#37 TheWatcher
TheWatcher
Posted 15 January 2022 - 01:50 PM
That Cave is going to be perfect for a 'more portable' 60mm setup primarily targeting AltAz or EQ if it doesn't add too much weight. waytogo.gif
Certainly not the first time two astronomers had different definitions of a "grab and go" setup! It is a wonder the IAU hasn't weighed in on the subject...yet!
#38 CHASLX200
CHASLX200
  • Loc: Tampa area Florida
Posted 15 January 2022 - 03:12 PM
Got this today.
 Has lots of slop and play above the DEC lock.
  • Bomber Bob and walter a like this
#39 Bomber Bob
Bomber Bob
  • Loc: The Swamp, LA (Lower Alabama)
Posted 15 January 2022 - 03:33 PM
Got this today.
Did you check the coupling(s)?  Some of these had a cradle attached, and the bolts below that can get loose...
#40 CHASLX200
CHASLX200
Posted 15 January 2022 - 04:09 PM
I will see what is up.
#41 Kasmos
Kasmos
  • Loc: So Cal
Posted 15 January 2022 - 04:16 PM
-7TE-2
-ATCO 1254
-Selsi 247
Of course the tube clamp would have to be larger on a 80mm, but is the mount itself the same size as on the 7TE and the ATCO 1254?
#42 Garyth64
Garyth64
  • Loc: SE Michigan
Posted 15 January 2022 - 04:23 PM
Yes, the 7TE and 1254 mounts are almost the same.  Some of these mounts have a different orientation for the dec cable.
Here is a Selsi 247 mount:
Even though this mount looks the same at the others, it is wider.  This mount for the Selsi is 1-7/8" wide, and the others are 1-1/2" wide.
  • Terra Nova, Bomber Bob, Kasmos and 1 other like this
#43 Bomber Bob
Bomber Bob
Posted 15 January 2022 - 04:30 PM
This EQ resembles the earliest TAK EQs, too...
(Wider across the polar axis at the latitude hub; and, with that polished metal end cap,)
Edited by Bomber Bob, 16 January 2022 - 02:17 PM.
#44 strdst
strdst
  • Loc: Oregon Territory
Posted 16 January 2022 - 12:09 AM
Tak and Tinsley make good mates. With so many much younger mounts in the neighborhood Tinsley was a bit concerned but Tak assured him he was ageless in her heart, and eye. Love conquers all
Edited by strdst, 16 January 2022 - 12:13 AM.
  • catboat, mdowns, Terra Nova and 6 others like this
#45 Kasmos
Kasmos
  • Loc: So Cal
Posted 16 January 2022 - 04:54 AM
What's that to the far right? It's mount looks very interesting.
#46 strdst
strdst
Posted 16 January 2022 - 02:10 PM
It's a Goto #453 3" X 1300 mm. It took me like all morning to figure this out as the mount photographed darker than the battle ship grey that it actually is.
  • Kasmos likes this
#47 Kasmos
Kasmos
  • Loc: So Cal
Posted 16 January 2022 - 03:11 PM
Goto, that figures as it's mount looks very substantial. Probably cast iron and heavy.
If you ever get a chance, I'm sure everyone would like to see photos of it.
