Need recommendations to raise my AP 900 mount a few inches
5 replies to this topic
#1 jerahian
jerahian
  • Loc: Maine
Posted 14 January 2022 - 12:58 PM
I have my AP 900 permanently mounted in my home observatory on a custom solid steel pier (purchased 2nd hand), the top of which has an opening which fits the AP Standard Pier Adapter for 900 Mounts.  The walls of my observatory are a few inches too high for this mounting setup and currently clips precious degrees off my Southerly view.  I only use the rig for imaging.
I would like to raise the mount by adding plates between a) the top of my steel pier and b) the AP 900 pier adapter.
I don't work well with metals, personally, beyond being able to drill a hole.  I also don't have a convenient metal shop contact, but anyone know of any off-the-shelf parts I can use or DIY ideas to effectively raise the mount by 4-5 inches??
Here is a photo of the pier in my observatory with the AP 900 pier adapter attached:
#2 MJB87
MJB87
  • Loc: Talbot County, MD & Washington, DC
Posted 14 January 2022 - 06:07 PM
Dan's Pier Plates sells riser kits. Check it out. It might work.
https://www.pierplat...ducts_3001.html
  • jerahian likes this
#3 jerahian
jerahian
  • Loc: Maine
Posted 14 January 2022 - 07:04 PM
Thanks for the recommendation.  I just checked out their website and sent them an email!  I hope they have a solution.
- Ara
#4 Binary Star
Binary Star
  • Loc: N.E. Ohio
Posted 14 January 2022 - 09:38 PM
Ara, if you haven't already done so it might be worth a call to Astro-Physics.  Although it doesn't look like they have a direct solution on their website, maybe they have a contact that could help since you're already using their pier adapter.
Jim R.
#5 Raginar
Raginar
  • Loc: Pensacola, FL
Posted 16 January 2022 - 12:41 AM
Two aluminum or steel squares. Some 1/2” threaded rods and nuts/washers to balance it out. Quick and easy.
  • MHamburg likes this
#6 Cosmo Geezer
Cosmo Geezer
Posted 17 January 2022 - 01:30 PM
Get a boat seat pedestal. They are cheap, sturdy and come in different heights and will bolt right up.
  • Raginar likes this
