Using an 8SE with Barlow and Full Frame Camera
#1
Posted 14 January 2022 - 10:33 PM
Two questions:
1. Will adding the Barlow in this case work?
2. If yes, exactly how can I do it and what do I need, other than the Barlow itself?
An image would be greatly appreciated.
#2
Posted 15 January 2022 - 03:16 AM
Camera: remove the lens, put a camera specific t2 adapter on.
Buy a t2-1.25 " nosepiece, connect that to the camera
Put the visual back into the scope
Put the barlow into the visual back
Put the nose piece into the barlow.
#3
Posted 15 January 2022 - 04:09 AM
Thanks for your help. 🙂
#4
Posted 15 January 2022 - 10:48 AM
The A7III is a full frame camera and the 8SE is not coma corrected. You may have noticeable coma, although depending on your presentation scale it may not bother you. Also I'm not sure I would use 1.25" components rather than 2". Depending on the Barlow it may induce chromatic aberration as well; I'm not familiar with the TV 2X.
Edited by Borodog, 16 January 2022 - 09:48 AM.
- Porkkala likes this
#5
Posted 15 January 2022 - 11:54 AM
But Borodog is right, with a full frame sensor the result may not be what you expect. Only a portion of the frame may be good enough for you.
If you're considering a barlow, you are probably trying to image details rather than the full disk of the moon. Instead of investing in a barlow, consider investing the same amount in a small planetary camera, with a pixel size of maybe 2.4 or 2.9 microns. The image scale with no barlow will be equivalent to what you'll achieve with the Sony + barlow, but the result will probably be better.
#6
Posted 15 January 2022 - 03:16 PM
