What catalogs are these stars from?
7 replies to this topic
#1 Chris K
Chris K
  • Loc: Long Island, Earth
Posted 14 January 2022 - 10:41 PM
Hi folks,
I'm expanding my carbon star list beyond the Astronomical League list.
I found a thread on CN where Bill Paolini provided a very nice list of carbons.
https://calgary.rasc.ca/redstars.htm
There are stars on the list that I have no idea of their catalog to be able to look them up.
I've tried punching in the coordinates in SSpro but have not had luck with that route either.
Maybe there's a site where I can reverse-lookup using coordinates and it tells me the star?
Here's some examples of the star IDs in the list. Fairly certain they're not HR, HD or HIP either.
C* 2138  (fairly certain the C* is not part of the ID# but can't figure it out)
2MASS J06365403+0305233
GSC 04046-00813
CD-26 298
VES 111
CPD-57 7255
Thoughts or suggestions much appreciated, I really want to see some of these!
#2 Alan French
Alan French
    Night Owl
  • Loc: Upstate NY
Posted 14 January 2022 - 10:58 PM
2MASS is the 2 Micron All Sky Survey
http://tdc-www.harva...logs/tmpsc.html
GSC is the Guide Star Catalog.
https://en.wikipedia...de_Star_Catalog
VES is probably VizieR Online Data Catalog.
https://ui.adsabs.ha.......0C/abstract
Clear skies, Alan
  • Chris K likes this
#3 RazvanUnderStars
RazvanUnderStars
  • Loc: Ontario, Canada
Posted 14 January 2022 - 11:03 PM
OP, you can search by coordinates through SIMBAD at http://simbad.u-stra...simbad/sim-fcoo
Also, you can use the search-by-id page at http://simbad.u-stra.../simbad/sim-fid and you get a list of alternate identifiers, maybe some will be known by your telescope controller.
  • Alan French and Chris K like this
#4 Chris K
Chris K
Posted 14 January 2022 - 11:10 PM
I'll try that thank you. I am my telescope controller LOL.
#5 Bill Weir
Bill Weir
  • Loc: Metchosin (Victoria), Canada
Posted 15 January 2022 - 02:56 AM
Yes Larry’s not Bill’s list is extensive. It also already has the coordinates on it and they are correct.
Simbad is the route to go. I simply randomly highlighted and copied one identifier and dropped it into the identifier query and Boom there you go.  http://simbad.u-stra...ubmit=submit id
Carbons can be fun but expect some of them to be very subtle. Sometimes it takes playing with magnification to get the colour to show. And sometimes it takes aperture to cover enough receptors.
Bill
  • Jon Isaacs and herschelobjects like this
#6 spereira
spereira
  • Loc: Bedford, NH
Posted 15 January 2022 - 09:41 AM
Moving to Deep Sky Observing.
smp
#7 beggarly
beggarly
  • Loc: Belgium
Posted 15 January 2022 - 10:26 AM
Old topics about 'carbon' stars: https://www.cloudyni...scension-order/
https://www.cloudyni...s-in-andromeda/
Edited by beggarly, 15 January 2022 - 10:32 AM.
#8 raa
raa
Posted 15 January 2022 - 11:29 AM
Hi folks,
GSC 04046-00813
CD-26 298
VES 111
CPD-57 7255
Some have beaten me to this, SIMBAD ID search is the best route, and although your result page may have a different title than the name you put in, that is because it allows a large number of cross identifications as well.  Most of the above will likely work.  The important bit to you is the C* bit, which I will mention last.
2MASS is a near infrared allsky catalogue
GSC is the Guide Star Catalogue.  Incidentally Tycho identifiers use the same system, except with an added number on the end often to show whether stars are single or not.  For example this star will be TYC 04046-00813-1 .  Sometimes things will work without the -1 at the end for TYCHO searches (eg software), or without preceeding zeroes.  Sometimes not.
CD and CpD are Durchmusterungs.  Look that word up in wikipedia.  CD is Cordoba (Argentina) CpD is Cape Photographic (South Africa), once upon a time you only had these to get down to magnitude 9.  You will have likely heard of BD for the common most Durchmusterun, these are southern hemisphere extensions.  The first one I think may have been SD, which took things just a bit more south than BD, at least I don't think it is called SBD, which would be unfortunate.
VES looks likely to be a red star list.  I'm wrong.  If you look at SIMBAD one link is to a 'nomenclature dictionary' and it says several but the likely one is Vatican Emission Star, which is a bit of a surprise for a carbon star.
C* is actually SIMBAD specific shorthand for carbon star, unique to simbad, someone has just copied it.
However, the number will be the number in the CGCS, which stands for Cool Galactic Carbon Star (interpret the word 'cool' however you wish).  The last edition was the second edition, or possibly the third?, and it too evolved from an earlier carbon star list.  In the past certain professional astronomers with a specialisation used to make compilation catalogues of specific types of objects by wading through the literature, and then people would notifiy them directly on new discoveries or they'd see them in new papers from targetted spectroscopic surveys or something and they would grow in size.  Most of these people have retired now and such catalogues are rarely udpated, but their data is still as valid today, especially in the magnitude ranges most amateurs will be able to achieve.
If you see something like C* 1234 then it will be CGCS 1234.
The full catalogue is available via VizieR, here is the direct link to the third edition (not all numbering stays the same in all editions) :-
https://vizier.u-str...r&-oc.form=sexa
if you clicked the all columns tickbox at bottom and typed in 2138 in the box with CGCS to the left of it you will get all the CGCS catalogue data available for that star.
Coordinates are a bit out of date, but you can use 2MASS for that.  It didn't work because the 2MASS identifier excludes the decimal point.  You have to add them.  2MASS identifiers use 1 decimal place for declination and 2 decimal places for RA.
J06365403+0305233 = RA 06h 36m 54.03s +03d 05' 23.3" in sexagesimal to J2000.  In SIMBAD you have to use spaces, so that would be 06 36 54.03 +03 05 23.3 in the coordinate box.  Use whatever your software prefers.
Finally, Guide by projectpluto has a system for showing carbon stars from this catalogue with little red x marks and the number in red, do a webearch on carbon stars and guide and projectpluto.  I would be surprised if similar is not available in other software.
  • GaryJCarter and RazvanUnderStars like this
