Beelink SEI8 - Power Supply
4 replies to this topic
#1 mexbound
mexbound
Posted 15 January 2022 - 09:54 AM
I have just installed my BeeLink SEI8 PC on my telescope mount.  I want to be able to bring the PC into the house at times so I want a second power supply to use in the house. I bought this: https://www.amazon.c...e?ie=UTF8&psc=1  but with all the supplied plugs, none of them fit the BeeLink PC.  Can someone point me to a power supply that would work with the BeeLink?, or what is the correct power plug size for the BeeLink?
#2 DesertCrawler
DesertCrawler
Posted 15 January 2022 - 10:28 AM
It is supposed to be a 5.5x2.5mm power jack. The PSU kit you purchased is supposed to have a 5.5x2.5mm plug.
Sometimes the plug, if spring loaded, can feel a little snug. You can measure them with calipers to convince yourself you do or do not have the right parts, but it looks like you should.
#3 mexbound
mexbound
Posted 15 January 2022 - 11:22 AM
Thanks for that info.  I'll again go through the plugs I got with the adapter. I do have MM calipers that I will also check ...
#4 mexbound
mexbound
Posted Yesterday, 02:24 PM
Ok, I found the correct adapter.  What is funny is, its the adapter that is the primary (the one it comes with wired/attached) to the AC/DC convertor. Did not need any of the 14 additional plugs it comes with.
#5 DesertCrawler
DesertCrawler
Posted Yesterday, 03:54 PM
Glad you got it sorted.
