Gotta give a shout-out to the kindly CNer who sent me the lens from his black Monolux 60x800 to test & potentially buy. W-O-R-K has really slowed me down! This past weekend I got the lens out of the cell, and started experimenting with spacers. Will post some pix tomorrow...
Classic Scopes & Classy Folks -- the Best Forum on this site!
Making & Testing Foil Spacers:
Good old Reynolds Wrap! My default spacer is 1 layer, 2 mm wide, and extends in from the flint edge about 2 mm. I do a quick check for Newton Rings using the fluorescent bulb in the hall bath.
This lens was like The 3 Bears: 1 layer too thin, 3 layers too thick; so, I pounded the 3 layers with a rubber mallet, rolled the foil piece flat, and got centered & symmetrical Rings. Each spacer is about 6 mm long, and I temp tape these tabs to the edge. Now that I'm happy with the spacing, I'll apply a tiny bit of glue off a Stick using a tightly wound Q-Tip. Let that set for a couple of days, then use my X-Acto to prune off the foil & tape.
Finally, I'll do a final lens cleaning, then put it back in its cell.
BIF: There's about a dozen or so "chips" in the R3 (sky face) edge of the flint. Not 1 is large enough to be a Clam -- nothing radiating out from the microscopic impact points. But... I had to choose my 3 x 120* spacer points carefully! Anywho, it must be abnormally flinty flint glass...
Otherwise, both elements are in excellent condition. No scratches. No coating degradations. Bet it does well on my DPAC Rig, and in star & sky testing. With luck, I can adapt its cell to my KDS-63/800 or my V60/700 (& use extenders).
Edited by Bomber Bob, 10 February 2022 - 05:04 PM.
