StarNet v2
Astrophotography Imaging Software
328 replies to this topic
#326 kopi
kopi
Posted 25 September 2022 - 08:05 AM
Those instructions seem Pixinsight-specific, as they're placing libraries in the Pixinsight path, rather than the StarNet one (which is fine if you're using Pixinsight, less so if you're not).
These instructions appear to be more applicable:
https://www.williaml...om/starnet-cuda
Sorry for the late response. I got a little distracted in the past weeks.
Today I checked the instructions you've linked and they work beautifully.
Thank you, kopi
  • JeffreyHorne and AaronH like this
#327 Glass17
Glass17
Posted 02 October 2022 - 04:48 PM
I've been enjoying StarNet2 in PixInsight, but noticed that if I apply it after I've run background extraction I get a check pattern in the white area of stars, particularly noticeable in larger stars. I avoid this by applying StarNet2 immediately after I crop and before running any other processes.
But I still have a problem. Sometimes I like to stack in Astro Pixel Processor and use its tools to crop, fix vignetting and light pollution and do background calibration and star color calibration. When I bring the resultant fits file into PixInsight and apply StarNet2, I get the check pattern in stars again.
I'm able to de-emphasize the pattern with PI l Convolution and Curves, but don't prefer this approach.
I'm hoping for a fix to this because the image from APP edits nicely in PI, but I don't want to do without StarNet or try a competitor.
Please advise.
I got the same and even reported it in my post from August 12.
Now I think I was able to  found where it is coming from - for me it is coming from drizzling.
If some quality advantages  even coming from drizzling (not much I can see in real life) 2x2 drizzling creates this grid pattern and slow down any further processing more then four time (I think five-six times at least). Going to give up on this and focus my time more on improvement other processing techniques.
#328 phtnnz
phtnnz
Posted 02 October 2022 - 05:24 PM
OSC data and Bayer drizzle? This yields similar artifacts around bright stars even without using StarNet2, at least in my case.
I switched to the new WBPP and separate processing of the R, G, B channels to avoid these problems.
#329 Glass17
Glass17
Posted 02 October 2022 - 08:40 PM
In my case mono and pysiril (Siril)
cmd.register(StackName, prefix="r_", drizzle=True)
It leads to check grid late with Starnet2 on COREs of the bright stars usually on bright phone of nebulas.
Take a look on the photo in my post here from August 12 2022
For pre-processing I prefer Siril and for processing I am going to PI
Edited by Glass17, 02 October 2022 - 08:41 PM.
Also tagged with one or more of these keywords: Astrophotography, Imaging, Software
