Hi Guys
Hopefully a quick one here. I have moved over to imaging at a greater focal length usually around 250mm to 1000mm. On the face of it the image seems fine but upon zooming in the stars are elongated quite considerably. This is all over the image all corners and centre so backspacing is not the issue here. What I am struggling to understand is why is this affecting the stars further away the bigger more prominent stars appear to be fine? Please see image at normal size and then zoomed at the centre. I am pretty sure this is guiding, but if someone can clarify please? I noticed that even after 10 seconds I see this trailing, but it doesn't appear to get that much worse all the way up to 180 seconds which is what these were shot at. Total RMS was roughly 1.2. Also I have found a way round this by shooting 5 seconds Lum images and then using Starnet and Pixel math, but this is not what I want to do... Thanks
