Labeling objects in Orion
Astrophotography Beginner DSLR Orion
6 replies to this topic
#1 FredOz
FredOz
  • Loc: Prescott, AZ
Posted 25 January 2022 - 11:50 PM
Hi All,
Last night I got the attached photo of Orion (Canon T3i, 50 mm f/1.8 lens @ f/2.8 596 exposures @ 2 sec each ISO 1600 on a fixed tripod, processed in DSS & Photoshop).  This from a Bortle 2 spot.
I've labeled some objects of interest.  Did I get the Running Man & M43 labeled correctly?
Edited by FredOz, 25 January 2022 - 11:51 PM.
  • Tim J Fowler likes this
#2 Jim R
Jim R
Posted 26 January 2022 - 12:02 AM
No, your label of running man is really the Flame nebula. I believe your label of m43 is really the running man.
  • Jim Waters, Tim J Fowler, Boeglewatcher and 3 others like this
#3 17.5Dob
17.5Dob
  • Loc: Colorado,USA
Posted 26 January 2022 - 03:46 AM
Both Running Man and M43 are wrong. What you have labeled as the Running Man is the Flame Nebula. What you labeled as M43 is the Running Man, but the Running Man is not M43. M43 is the small comma shaped appendage attached to the top of M42 in your image.The Running Man is the separate nebula, SH2-279 that you have labeled M43..
Edited by 17.5Dob, 26 January 2022 - 03:50 AM.
#4 Tim J Fowler
Tim J Fowler
  • Loc: Seneca, South Carolina
Posted 26 January 2022 - 07:15 AM
If you use Siril, you can use the "Show Object Names" function and then take a snapshot of the displayed image. I would imagine that other programs have a similar function. Here's an image of mine (Also using a Canon T3i, but with a 200mm SMC Takumar lens) from the other night just to give you an example, but as you can see, there's a lot more going on in that area than just the famous targets, so it can get a little cluttered. However, using a program like Stellarium will let you easily identify objects if you wish to label them yourself.
Edited by Tim J Fowler, 26 January 2022 - 07:19 AM.
  • kraegar and 17.5Dob like this
#5 jiawen
jiawen
Posted 26 January 2022 - 09:43 AM
You could also try uploading your image to http://nova.astrometry.net/upload , which will attempt to automatically platesolve and label your image.
#6 Jim R
Jim R
Posted 26 January 2022 - 10:46 AM
To the OP; BTW, lucky you to have a bortle 2 location!!
#7 FredOz
FredOz
  • Loc: Prescott, AZ
Posted 26 January 2022 - 04:32 PM
Thanks for the corrections on my labeling and the tip about Stellarium, which I use a lot.  I didn't realize it would identify so many deep sky objects.
And yes, I feel fortunate to have reasonably dark skies around Prescott.  FYI, I was at Tonto Rd., just off Iron Springs Rd. about 15 mi WNW of downtown Prescott.
Also tagged with one or more of these keywords: Astrophotography, Beginner, DSLR, Orion
