The JPL Horizons ephemeris system, at
https://ssd.jpl.nasa...zons/app.html#/
will allow you to make tables of the position of any body in the Solar System. The results are accurate. For 7 Iris, it lists the following positions for the period between UT Jan 26 and UT Jan 28:
Date__(UT)__HR:MN R.A._____(ICRF)_____DEC dRA*cosD d(DEC)/dt Azi____(a-app)___Elev APmag S-brt
2022-Jan-26 00:00 07 23 57.35 +15 44 25.4 -34.1691 1.682815 96.193492 29.756126 8.095 4.718
2022-Jan-26 01:00 07 23 54.97 +15 44 26.9 -34.4510 1.628477 108.136490 40.491625 8.097 4.719
2022-Jan-26 02:00 07 23 52.58 +15 44 28.5 -34.6662 1.553754 123.302483 50.398018 8.098 4.720
2022-Jan-26 03:00 07 23 50.17 +15 44 29.9 -34.7975 1.464021 144.266361 58.370788 8.100 4.721
2022-Jan-26 04:00 07 23 47.76 +15 44 31.2 -34.8335 1.365684 172.699142 62.459854 8.101 4.722
2022-Jan-26 05:00 07 23 45.35 +15 44 32.5 -34.7692 1.265732 203.352206 60.898172 8.103 4.723
2022-Jan-26 06:00 07 23 42.94 +15 44 33.6 -34.6064 1.171266 227.848897 54.444867 8.104 4.724
2022-Jan-26 07:00 m 07 23 40.56 +15 44 34.7 -34.3539 1.089004 245.351156 45.252598 8.106 4.725
2022-Jan-26 08:00 m 07 23 38.19 +15 44 35.7 -34.0266 1.024826 258.530387 34.808173 8.107 4.726
2022-Jan-26 09:00 m 07 23 35.84 +15 44 36.6 -33.6442 0.983366 269.487747 23.888674 8.109 4.728
2022-Jan-26 10:00 m 07 23 33.53 +15 44 37.5 -33.2306 0.967696 279.511034 12.943419 8.110 4.729
2022-Jan-26 11:00 Am 07 23 31.24 +15 44 38.4 -32.8116 0.979119 289.453078 2.311421 8.112 4.730
2022-Jan-26 12:00 Nm 07 23 28.98 +15 44 39.3 -32.4134 1.017075 299.979187 -7.666814 8.113 4.731
2022-Jan-26 13:00 *m 07 23 26.75 +15 44 40.3 -32.0606 1.079187 311.674439 -16.578045 8.115 4.732
2022-Jan-26 14:00 *m 07 23 24.54 +15 44 41.4 -31.7750 1.161420 325.018289 -23.889545 8.116 4.733
2022-Jan-26 15:00 *m 07 23 22.34 +15 44 42.5 -31.5734 1.258362 340.188754 -28.957773 8.118 4.734
2022-Jan-26 16:00 *m 07 23 20.16 +15 44 43.7 -31.4672 1.363592 356.746916 -31.161983 8.119 4.735
2022-Jan-26 17:00 * 07 23 17.98 +15 44 45.1 -31.4609 1.470124 13.564144 -30.170459 8.121 4.736
2022-Jan-26 18:00 * 07 23 15.80 +15 44 46.6 -31.5524 1.570885 29.361170 -26.137748 8.122 4.737
2022-Jan-26 19:00 * 07 23 13.61 +15 44 48.1 -31.7327 1.659199 43.411887 -19.608094 8.123 4.738
2022-Jan-26 20:00 * 07 23 11.40 +15 44 49.7 -31.9869 1.729245 55.693254 -11.240927 8.125 4.739
2022-Jan-26 21:00 * 07 23 09.18 +15 44 51.4 -32.2949 1.776456 66.602206 -1.617680 8.126 4.740
2022-Jan-26 22:00 * 07 23 06.93 +15 44 53.1 -32.6329 1.797831 76.694568 8.806281 8.128 4.741
2022-Jan-26 23:00 N 07 23 04.66 +15 44 54.9 -32.9751 1.792142 86.598803 19.669775 8.129 4.742
2022-Jan-27 00:00 07 23 02.36 +15 44 56.6 -33.2954 1.760017 97.074815 30.643444 8.131 4.743
2022-Jan-27 01:00 07 23 00.04 +15 44 58.2 -33.5693 1.703895 109.203355 41.338385 8.132 4.744
2022-Jan-27 02:00 07 22 57.71 +15 44 59.8 -33.7753 1.627863 124.730338 51.140281 8.134 4.745
2022-Jan-27 03:00 07 22 55.37 +15 45 01.4 -33.8966 1.537371 146.283099 58.884206 8.135 4.746
2022-Jan-27 04:00 07 22 53.02 +15 45 02.8 -33.9225 1.438859 175.220891 62.562317 8.137 4.747
2022-Jan-27 05:00 07 22 50.67 +15 45 04.1 -33.8484 1.339315 205.625374 60.539493 8.138 4.748
2022-Jan-27 06:00 07 22 48.33 +15 45 05.3 -33.6768 1.245793 229.495308 53.787002 8.140 4.749
2022-Jan-27 07:00 07 22 46.01 +15 45 06.4 -33.4169 1.164933 246.547769 44.450243 8.141 4.750
2022-Jan-27 08:00 m 07 22 43.70 +15 45 07.5 -33.0840 1.102501 259.482499 33.944880 8.143 4.751
2022-Jan-27 09:00 m 07 22 41.42 +15 45 08.5 -32.6981 1.062995 270.324067 23.009194 8.144 4.752
2022-Jan-27 10:00 m 07 22 39.17 +15 45 09.5 -32.2832 1.049338 280.312169 12.077487 8.146 4.753
2022-Jan-27 11:00 Am 07 22 36.95 +15 45 10.5 -31.8650 1.062678 290.277405 1.485497 8.147 4.754
2022-Jan-27 12:00 Nm 07 22 34.76 +15 45 11.5 -31.4696 1.102309 300.876162 -8.422789 8.149 4.755
2022-Jan-27 13:00 *m 07 22 32.59 +15 45 12.6 -31.1212 1.165722 312.687734 -17.225902 8.150 4.756
2022-Jan-27 14:00 *m 07 22 30.44 +15 45 13.7 -30.8412 1.248779 326.176794 -24.380815 8.152 4.757
2022-Jan-27 15:00 *m 07 22 28.31 +15 45 14.9 -30.6461 1.345994 341.483255 -29.238943 8.153 4.758
2022-Jan-27 16:00 *m 07 22 26.20 +15 45 16.3 -30.5463 1.450914 358.108449 -31.192204 8.155 4.759
2022-Jan-27 17:00 *m 07 22 24.08 +15 45 17.7 -30.5461 1.556559 14.884482 -29.943921 8.156 4.759
2022-Jan-27 18:00 * 07 22 21.96 +15 45 19.3 -30.6427 1.655900 30.555519 -25.687605 8.158 4.760
2022-Jan-27 19:00 * 07 22 19.83 +15 45 20.9 -30.8267 1.742346 44.455533 -18.986927 8.159 4.761
2022-Jan-27 20:00 * 07 22 17.69 +15 45 22.6 -31.0828 1.810187 56.607597 -10.499842 8.160 4.762
2022-Jan-27 21:00 * 07 22 15.52 +15 45 24.4 -31.3906 1.854993 67.428587 -0.797739 8.162 4.763
2022-Jan-27 22:00 * 07 22 13.34 +15 45 26.2 -31.7262 1.873913 77.480899 9.673426 8.163 4.764
2022-Jan-27 23:00 N 07 22 11.13 +15 45 28.0 -32.0639 1.865872 87.399559 20.557663 8.165 4.765
Note that the Dec listed here is always considerably to the North of the value you observed (+15 38). It appears that your source for the position was at fault.
