I dont know if it qualifies as classic scopes. I acquired a used Celestron 125mm f/6 telephoto lens. It has a huge secondary mirror, came with a small mount which could be screwed directly to a arca swiss plate and mounted on a ball head.
it certainly looks very old design, has a label says made in USA and has a 4 digit serial number.
I tried to unscrew the photo mount and see if I could attach a standard vixen dovetail but it wasnt possible. the distance between the two screws was too wide to attach the vixen dovetail. So I got a 140MM Vixen mounting ring and they fit perfectly. I have ordered a smaller 150mm vixen doevtail, but in the meantime have mounted it on a 210mm vixen plate. The rings are white in colour, I could not get a black ring.
It balances very well on a az gti. I had an hour of clear skies before clouds rolled in, the stars are sharp and round. The view was quite bright compared to my F/10 C6, I guess it has to do with f/5.6 even though it has 5inch aperture compared to C6. I was thinking the collimation would be terrible, but surprising it held very well. I checked in out of focus disks and they look very different with a huge central disc (which is probably due to large central obstruction). I will try to fine tune collimation before I try any photography.. For visuals the stars are good.
This looks like an ultimate light weight setup - az gti, carbin fibre tripod and C5 f/5.6.. the rings look more heavier than the scope. Any suggestions for better rings.
