So I’ve never owned a goto Dob and haven’t had a chance to get this out for first light with this weekend being no exception (we’re having a blizzard as i type). Not sure how accurate and smooth the goto and tracking will be at 4000mm. The scope needs a finder and I haven’t decided what to do…..would a simple 9x50 RACI up front do the job or should I mount an old 80mm frac on the bottom tube with a diagonal and crosshair eyepiece?
Also on Barlows?…..I’ll be using the ASI224mc with 3.7u pixels so with the 5x guidance I’m at F18.5. The native Fl and ratio of this scope is 1650 at 4.6. Equipped with a 4x Barlow gives me an f ratio of 18.4….right on the theoretically ideal for my camera……..is this ok or will it only work in excellent seeing?
