A second attempt at Mars this morning between 4.30 and 5.00 local time with the planet between 5o and 10o above horizon. At least I saw it but I could make out no detail. Pretty good seeing with the outline moderately well defined at times so I thought I'd be able to make out the SPC but no luck. I expect I was being over optimistic with the altitude being in only single figures although I did see a mention of dust storms around Hellas. But I doubt if that's the explanation.
To counter atmospheric dispersion I had picked out a few microscope slides with reasonable figures and knocked up a couple of 2o prisms using uv cured optical cement which were held up to the eyepiece. They helped but a bit more experimentation needed but that will wait until the end of the month.
Magnifications of x60 and x120 with the 8.5'' slow Dob.
David
Edited by davidc135, 07 May 2022 - 03:33 AM.
