Anyone know the history of this scope ?
19 replies to this topic
#1 Jae
Jae
Posted 18 October 2006 - 09:16 PM
It's a Holmar 60mm F15. Mount seems to have the same insides as the Tasco 7TE in the background or a Mayflower/Scope.
Jae
#2 Jae
Jae
Posted 18 October 2006 - 09:17 PM
Neat counter weight holder in the box...
#3 Jae
Jae
outside
#4 Jae
Jae
Posted 18 October 2006 - 09:18 PM
more
#5 Jae
Jae
5
#6 Jae
Jae
Posted 18 October 2006 - 09:19 PM
6
#7 Jae
Jae
Posted 18 October 2006 - 09:20 PM
7
#8 Jae
Jae
8
#9 Jae
Jae
Posted 18 October 2006 - 09:21 PM
9
#10 Jae
Jae
Posted 18 October 2006 - 09:24 PM
So this thing is in great condition, with some black crinkle paint flaking off the metal on the legs. Someone must sell crinkle paint. The mount is solid, the box is like wow.....
Alas...the lens seems to have a bit of spherical aberation, so the image is good to about 100x, a bit soft but no color. Not as sharp as the Tasco in the background.
#11 trainsktg
trainsktg
Posted 18 October 2006 - 09:50 PM
Hmmm...it looks like the lens is air-spaced. Try loosening the retaining ring and indexing the lenses...you might be able to counter the defect somewhat. I like the spots-on-black crinkle finish.
Keith
#12 Jae
Jae
Posted 18 October 2006 - 10:01 PM
Hi Keith,
What do you mean by indexing the lenses? I tried a thinner spacer and it was worse so I put the original spacers back.....I was thinking maybe thicker spacers ?
#13 droid
droid
    rocketman
Posted 18 October 2006 - 10:38 PM
Jae I think he means try turning it clockwise or counterclock wise which ever you prefer, very slowly, turn a little retighten and test, if needed loosen turn slight agin, retighten and test, etc.
Now for the pretty factor , wow thats a swet looking scope, has some novel ideas in it like the small window in the mount for the numbers to be read through.Way cool.
If I might, where did you find this scope???
#14 Clive Gibbons
Clive Gibbons
    Mostly Harmless
Posted 19 October 2006 - 08:40 AM
If the lens is showing a lot of spherical aberration, there's a good chance that someone has removed it sometime in the past to clean it, but put it back in it's cell in a reversed position.
I've seen that sort of thing a few times.
If you don't mind removing the lens from it's cell to check this,
the front lens should be double-conxex in shape, with a thinner edge thickness than the rear lens. If you find the front lens is thicker at the edge then the rear lens, they've been reversed. (Assuming a normal Fraunhofer-type achromat)
Hope this helps.
Clive.
#15 Selecter
Selecter
Posted 19 October 2006 - 09:17 AM
go to any Harley cycl dealer for the best spray can of black wrinkle money can buy. Do google search on how to shoot the stuff, its not like shooting normal paint. The subject needs to be about 130 degrees F to get the paint to wrinkle properly.
thats a bad looking scope.
#16 Jae
Jae
Posted 19 October 2006 - 02:51 PM
Hi Clive,
The lens is facing the correct way, I suppose the convex element could have been reversed but not sure how that would affect it. Thanks.
Jae
#17 jouster
jouster
Posted 19 October 2006 - 09:06 PM
I know nothing about it, but it sure is a good looking scope.
#18 Darenwh
Darenwh
Posted 19 October 2006 - 10:01 PM
That classic scope looks nice. It seems to be an obscure model as well. Nice...
#19 Selecter
Selecter
Posted 20 October 2006 - 02:10 AM
I guess the cloudiness in the objective isnt really there? light reflections?
I love stuff like that. That black wrinkle finish is the schiznit.
#20 Jae
Jae
Posted 20 October 2006 - 11:48 AM
Thanks everyone for nice remarks. :)
The crinkle is tighter than the circle T crinkle.....it is cool. I surprised at the slight variations on this particular mount used by Tasco, Mayflower, Bushnell, etc. Seem to have the same exact axis adjustments i.e end of polar axis and little hole for the dec axis.
The lens is not cloudy but just the reflection......I'll tinker over the weekend.
This scope is an obscure one. It seems that Holmar may have made/labeled some binoculars as well but the company must have been short lived.
