Oh, you have picked a very fine microscope brand and model. Great job! Just maybe not the right example.
What are your intended applications, beyond toilet tissue?
(Just teasing you.)
Check out the excellent links ASAP.
If you search, you’ll find the microscopy references that I recommended in other microscope threads.
Quotes from knowledgeable posts of -jgardavsky.
“With the Leitz optics, it makes sense to spend some more money on the Leitz APO objectives, or at least on the Leitz Fluotar objectives.” (#4)
-Good upgrade, my pick, too, but pretty advanced. Perhaps use it first as the optics may be (ARE) just dandy as they are for YOUR applications. I suspect you’ll never feel the need to upgrade ($$$) if you wait. Do you know how to properly set up a compound microscope for critical lighting? (You can learn -check general references.) If not, upgrading the optics will definitely not be a good use of money right now.
-The power supply is typical (robust, massive and complicated) for that time. Power must be extemely stable, and the unit safe. This was the way Leitz addressed those criteria, Again, check the links. Become informed before you buy.
“to feed the 12V halogen lamp through an external voltage convertor.” (#7)
-Should work. Maybe. But do you want your first microscope to come with issues built in?
-Or (better): don’t buy the microscope unless they discount it enough for you to buy replacement part(s).
-Or (best): find a microscope w/o issues. Just my assessment.
I have one (or two) of these nice microscopes. Plus a very sweet Dialux 20. All favorites of mine. (Nice scopes, but not particularly rare.) Have learned to be very careful about buying into problems with any used microscopes. That way, avoiding breaking the bank and the heart
Red flag #1: Illumination power supply. I think you are unlikely to fix it (difficult and uneconomical). Replacement parts are the answer. $$$ and finding them.
Red flag #2: The “focuser” issue is a bit worrisome. Might just be adjustments, simple or complex. Or relubrication. Are you willing to buy specialty greases? I have several small tubes/jars that cost me >$60 each.
Me? I’d pass.
Find a used, older microscope (there are many from Nikon, Olympus, Leitz (Leica)) in full working order. Use extra funds to swap out the oil immersion objective for say, a 20x. You'll likely find the oil immersion procedures tiresome.
Leica service may be helpful for information (probably not). Very expensive for actual repairs. Start with the links.
I successfully purchased most of my 20 or 25 compound microscopes on eBay by being very careful, very patient, and by asking a lot of questions. Some were from private owners or via oddball sites such as Goodwill Online.
CS, and fair sailing into microscopy,
Brian
Edited by Brianm14, 16 February 2022 - 09:38 AM.
