I've been doing a good bit of research on this, and am a little frustrated, so any help will be much appreciated.
Wanting to simplify life a bit, I'm pretty much down to just one scope for imaging now, my 9.25" EdgeHD. I want to concentrate on DSOs, particularly some of the more difficult ones, to get out of the envelope of just shooting the "usual" stuff. Currently I'm using a 50mm Stellarvue F050G for guiding on my CGX, and on good nights of seeing I can get as low as .5 - .6 arcseconds RMS using PHD2. Normally seeing here (Green Valley, Arizona), despite a good dark sky, is usually pretty average, so more like .8 - .9 arcseconds on a normal night. I'd like to do better, but I definitely do not wish to go the OAG route. Been there, done that, did not like it at all, and I'm getting nice star images even with 3-4 minute exposures. Longer than that starts to get iffy.
I get excellent star fields and pinpoint stars with the SV50, but it only has a focal length of 210mm. Using a Nikon D810 for imaging, and doing the calculations, my imaging/guiding ratio is worse than 1:6. So, I assume if I can bring that down closer to 1:3 I can get even better guiding and imaging results. I have tried an Astromania 60mm (240mm f/l), but was not real happy with the star images and field. I tried an Astro-Tech 72ED, and it needed an extension tube to come to focus so I never used it. My current setup is rock solid - I've done everything possible to eliminate flexure and am sure it has worked, so I have no desire to add an extension tube.
Again, no desire for OAG either. I'm looking for suggestions for a good, solid guidescope with around 400mm focal length, for a few hundred dollars at most. If it turns out that my SV50 is the best I'll be able to do, so be it. It's a great scope. Of course, another issue at the present time is availability, but please don't let that be a consideration. Any and all suggestions welcome (EXCEPT OAG! ).
Thanks for your time!
