I'm doing imaging and visual with it.
Would the pictures be better? How much more detail could I see with an eyepiece?
Experience has shown me that bigger is virtually always better in almost all ways when talking about imaging or visual observation and this is especially true for refractors. The only ways smaller telescopes are better is in conveience, cheaper, easier to store, transport and you can get away with a smaller cheaper mount.
100mm is really the minimum for visual observation, you need a certain amount of light to see objects in a meaningful way. Bigger is better but if you go much bigger than 130mm f/7-ish the scope gets longer and heavier than even most people under 50 want to deal with. It is not that they are heavy they are awkwardly and inconveniently shaped and easy to break. Plus at this point even for visual you will need at a minimum a 30-40 pound payload mount to get steady views or to image with and a higher payload is suggested due to the long polar moment of a 5" class refractor. People don't buy a good 130mm apo and then turn around and try to image on a small mount, it is a waste of money to do so.
All things being equal the 130mm optic will objectively outperform the 115mm scope. But that means you have to a mount that is capable of guiding at sub arc second 100% of the time you are capturing data. The rule is generally about 1/2 to 1/3 of your seeing limitations so if you live under steady skies and the seeing is 1"-2" arc seconds if you know how data sampling theory works you know you need a pretty good mount and guiding system to let the telescope show you what it can do.
So sure if you have the mount and skills to manage the data capture at this level IMO a 130mm.is better. As a newer imager I imagine mastering your current tools will be enough of a challenge that you don't need the larger scope. Unless of course you have more.money than sense in which case go for it.
Edited by YAOG, 10 June 2022 - 01:09 PM.
