You always want to have measurements in an alternative laboratory of filters in 2023, and not in 2018, for example, 5 years ago.
Time does not stand still, production can change, even the top Lumicon filters have changed beyond recognition in 5 years and there is no stability. And it was impossible to rely on measurements of filters made 5 years ago, even with Lumicon.
The measurements from your link are distrustful, at least about 99% for TeleVue Oiii, when 94.7% is indicated on the box. I don’t trust the laboratory from your link Don. Either I should not trust what is indicated on the box and trust the tests on your link. There are differences, and strong ones. No offense.
I find that peak transmission varies, from having 10 samples at a time in inventory, from 93%+/- to close to 99%+/-
That is the nature of filters--there is at least a +/- 2-3nm difference in bandwidth and bandwidth placement among a batch of filters, and up to a 6% difference in peak transmission.
The cheaper the filter, the larger that variation seemed to be among the filters I sold for many years.
There is no batch of filters where the transmission peak is identical from filter to filter.
I agree that seeing tests for current batches is desirable, but simply not possible when the manufacturers are not testing each individual filter and giving you test data with each one
(the most recent Lumicon filters, for example, tested one filter in a batch, then provided that same graph with every filter in the batch).
You would have to buy filters and have them tested at the same time, which is what I did with ~50 filters.
The TeleVue BMII O-III box for the high transmission filter said peak transmission 98.7%, by the way, and I regard a measurement of +/- 2% to be within tolerances for measurement accuracy.
I note that, as is typical for filters, the higher the transmission, the wider the bandwidth.
And if you look closely at the TeleVue BMII O-III tests on the Semrock site, you'll see that holds true with the TeleVue BMII O-III filters as well.
Since the Astronomik filters tested were current ones (from batches after they changed specs, and identical to the TeleVue BandMate II O-III), you can superimpose those curves on the TeleVue BMII O-III filters as well.
It will give you some examples of how the bandwidths and bandwidth placements vary from filter to filter.
The curves on the site are generated by an independent lab, having no affiliation with any manufacturer and represent actual lab measurements with the same instrument.
The latest specs of filters occurred in:
2016-17 for Astronomik
2018 for TeleVue
2018 for Lumicon
The specs have not changed since then, though individual filters will vary, sometimes distressingly so.
It's always desirable to test an individual filter to see what you get.
Look at the Lumicon UHC filter 2018 (a Gen.3 filter) on the Semrock site to see how high transmission can get.
That filter measured 99.8% at 486nm, 99.5% at 496nm, and 99.3% at 501nm.
It was about 7% higher transmission than a 2010 Lumicon UHC filter, but the bandwidth was quite a bit wider on the 2018 filter (FWHM bandwidths 27nm vs.22nm).
Despite the lower transmission, the narrower bandwidth filter yields better contrast and outperforms the newer one.
