As someone probably less experienced than many here, I'd like to better understand why you'd ever choose a slow refractor over a faster one. Common wisdom suggests a slow "planet killer" scope for planetary, double stars and lunar, and a faster one for wide field views of DSOs the Milky Way and, of course, for AP. Before the advent of fast and fairly affordable apochromats, most achromats were comparatively slow (typically f/8 or higher). Consider, for example, a fast and slow (say f/5 and f/10) apochromat of the same aperture. Further assume both have similar quality optics. Using the rule-of-thumb maximum 50X/inch of aperture, both scopes should show the same level of detail at high magnification. Obviously, the f/5 scope will need an eyepiece with double the power or a 2X Barlow to achieve the same magnification as the f/10. The question is, does the fast apochromat give up anything to the slower for high magnification views? Does the fact that a slow achromat shows less false color than a faster one apply to apochromats as well? In other words, in general, is a slow apochromat better corrected than a faster one? Does field curvature, which I understand would be greater in faster scopes, come into play when viewing planets at higher magnifications? I guess the bigger question is, can a fast apochromat serve equally well both as a wide field and planetary/double star/lunar instrument?
Larry
