EAA Monthly Observing Challenge - April 2022
45 replies to this topic
#1 Stargazer3236
Stargazer3236
  • Loc: Waltham, MA
Posted 01 April 2022 - 10:02 AM
In the words of our dear departed TV astronomer Jack Horkhimer “Greetings, Greetings Fellow stargazers!”
This month’s Challenge involves many of my favorite planetary nebula. I will throw in a few Spring galaxies to mix it up!
Firstly, let us look at some bright planetary nebula.
M97 in Ursa Major. Known as the Owl nebula, it looks great in any telescope, but with more aperture gains more details. I have imaged this masterpiece with everything from a 60mm APO to a 14” Dob. Viewing visually is just as rewarding, however, by eye, it is a featureless gray blob. Attaching a camera to your telescope reveals a grand cacophony of vivid reds and greens. At magnitude 9.8 and a diameter of 3.4 x 3.3 arc min, it is a fairly large planetary nebula. If you have a small enough scope and large enough camera sensor, you can view M108 in the same field of view.
NGC 3242, standing nearly on the meridian tonight, underneath Regulus, is the often quoted Ghost of Jupiter. Herschel first described this planetary nebula as a shadowy spectre of Jupiter, albeit smaller. At magnitude 7.3 it is two magnitudes brighter than M97, but nearly 3x smaller. At 42” x 36”, it is a more compact planetary nebula, which pales in comparison to M97 in size, but not in splendor! Upon magnification or zooming with your camera sensor, after a few stacks of lights, you begin to see a smaller disk within the surrounding glow of the nebula. The stellar white dwarf at the center glows at magnitude 12.1, easily seen both visually and by camera. Using a narrowband filter greatly enhances this beauty of the deep sky wonder, bathing in a greenish glow, sometimes seen as blue without a filter.
NGC 2022, seen early in the evening for a few hours, is a very nice planetary nebula near the head of Orion. At magnitude 11.69, this planetary nebula shows remarkable detail when imaged with an 8” or larger. It has a well defined ring, with two stars implanted within that ring, each opposite of the other. It has a nebulous outer shell, viewed with a long exposure. Its size, however is small at 30” x 30” in diameter.
Abell 12, is another of my favorite planetary nebula. It is easy to find, basking in the glow of a nearby star, Mu Orionis. At magnitude 12.4, it is easy to see with a scope of 6” or larger. You would be best served to see it if you used a Dual or Single narrowband filter, say an L-eXtreme or OIII. It is a featureless pale glow, no discernible features, unless you have a larger scope or longer exposure times. Always a treat to view!
NGC 2438, living in the area of M46, is a nice colorful planetary nebula to view. With any OSC camera, you can see colors of red and mostly green. It is embedded within M46, although astronomically speaking, it is closer to us than the open cluster, it just so happens to be in our line of sight. It is large, however, being 72” x 66” in diameter.
NGC 2392, know in some circles as the Eskimo nebula and to others as the Lion headed nebula or the Clown nebula, sporting a mane of hair on the outside of the nebula. This object is magnitude 9.2 and 56” x 48” in diameter. There is a star in the same field of view, but when viewing at a large field of view, the nebula looks like another star until you zoom in on the nebulous star and see it take the shape of the rounded nebula. Larger scopes will reveal the minute details of the ‘Hood’ and possibly see the small striations of red nebulosity in a small arc at the top of the head. The central area of the nebula has intricate loops of nebulosity, mostly seen with the largest of scopes and longest of exposures. A fine gem of a nebula to observe and image!
Now for some slightly more difficult objects.
NGC 2346, located in Monoceros, is a fairly large, but slightly dim planetary nebula. Glowing at 11.9 magnitude, this 60” x 48” diameter nebula is easy to discern using a narrowband nebula filter. In the glow of OIII, it looks like a pale green glow, with a very prominent central star.
NGC 2440, located in Puppis, resembles the oft named Bow Tie nebula NGC 40 in Cepheus. It has a really dense, over saturated central region, with tendrils of red nebulosity branching off in opposite directions. A good long exposure with your camera will eventually tease out these tendrils if you stretch the image. At 9.3 magnitude and 72” x 42” in diameter, it is a nice planetary nebula to view.
NGC 2371/72 is a double lobed planetary nebula in Gemini. It was misclassified because it was originally seen as two distinct lobes and not until long exposure photos were used, it was determined to be classified as two nebula, NGC 2371 and NGC 2372. However, if you stack many frames for a long time exposure, you will see that this 11.2 magnitude object is indeed the same nebula. You will eventually see that this nebula appears to be a Yin Yang looking nebula with the two lobes going in opposite directions. Further stretching of the image reveals faint outer crescents on either side of the nebula. This object requires a narrowband filter to see its full form. It is 72” x 56” in diameter.
NGC 1535, in Eridanus, known as Cleopatra’s Eye, is another hooded planetary nebula. Located west of Rigel, it is a magnitude 9.39 and 56” x 42” diameter nebula. It has a condensed central region and a diaphanous outer hood, where within this hood lies a star. The central star of the nebula is quite bright. My best pic of this was done with a Nexstar 6SE telescope and my then camera, an ASI224MC camera. A nebula narrowband filter is needed to tease out this diaphanous hood.
NGC 1514 in Taurus, is a sight to behold. Called the Crystal Ball nebula, this object of magnitude 11 and 138” x 120” in diameter, is large, but not that hard to see. It has a bright central star and a nearby close companion and the wispy tendrils of nebulosity surround this star. Like M97, this nebula has ‘eyes’ of a sort and is best seen after a long and stretched image of the object. A narrowband filter is best used to see this fainter nebulous glow.
NGC 1501, in Camelopardalis, is in a region devoid of any bright stars and hence is difficult to find. Using Goto will get you there with little difficulty. This nebula is often called the Oyster nebula. It is another hooded object, with a bright central star and a ‘hood’ of nebulosity surrounding it. I would consider using a narrowband filter on this one, as the nebula itself is dimmer. But once captured makes for a great addition to any observing list.
Now for some Challenges!
I am fond of the ‘obscure’ planetary nebula with names like Kohoutek, Minkowski, Abell just to name a few. Here are a few difficult objects for you to find.
OH 231.84 +4.22or better known as the Calabash or Rotten Egg nebula, sits in the nearly same field as NGC 2438 in M46. It is an extremely small planetary nebula or Proto-planetary nebula. Named so because of the sulfur compounds in its chemical makeup. This object is part of M46, with the same radial velocity as the star cluster. It is magnitude 9.5, but is only 60” long. It looks like an upside down egg beater, if you remember what they look like. It is within 5 diameters of NGC 2438 away from NGC 2438. I have seen it in my images of M46 and NGC 2438. It is often a featureless long strand of nebulosity.
Minkowski 1-7, is a planetary nebula located in Gemini. Magnitude 13.5 and a diameter of 18” x 12”. It sits between a fairly bright star at 10th magnitude and a fainter star. It is a pale green disk with a little faint red on the periphery. A narrowband filter is a must when imaging this small planetary nebula.
Minkowski 1-8 in Monoceros, is a similar looking planetary nebula, just like M 1-7. It is a pale-ish green disk, with a faint outer ring of red Ha. There is a small dark streak bisecting the nebula. This magnitude 14.3 nebula is 24” x 12” in diameter. A narrowband filter is required to image this small planetary nebula.
Abell 33 in Hydra, is a large tenuous disk of nebulosity. This 12.0 magnitude planetary nebula is not to be taken for granted, because of its large diameter of 276” x 258”, it is faint as all get out! When imaged, it takes on the effect of a Diamond Ring because of the bright 7.2 magnitude star located on the rim of this big nebula. This nebula is almost perfectly round, much like Abell 39 in Hercules. This nebula is round with some visible pillars with in it and a somewhat dark streak running through the middle. Many fainter stars are embedded inside this nebula. The nebula is situated within a triangle of 8th and 9th magnitude stars. GoTo is required to find this object as well as narrowband filters.
Abell 34 is also in Hydra, not too far away from its sibling. This is also a very large planetary nebula at about 290 arc seconds in diameter. It glows at magnitude 12.9, but because of its large size, its surface brightness is quite low, around magnitude 15+. It is a diaphanous disk, with a brighter ring and two brighter crescents on either side of the ring. It has two faint galaxies as part of one of those crescents. Many fainter stars are embedded within the disk of nebulosity. There are two brighter stars, 9.7 and 9.2, flanking the nebula, making for a sort of makeshift triangle including the nebula. GoTo and narrowband filters are also required in imaging this nebula.
And now for some ubiquitous galaxies.
Ursa Major is high in the sky this time of year, so should be quite advantageous to find these often overlooked gems!
NGC 3583 is a spiral galaxy, magnitude 11.3 and 132” x 78” in diameter. One side of the galaxy has one spiral arm, while the other side sports 3, one under the other under another. The one spiral arm has a sort of hook at the end of the arm. There is a faint galaxy located to the side of the nucleus. A fainter edge on spiral galaxy is located nearby, surround by what looks like a faint ring.
NGC 2841 is a gorgeous galaxy, similar in shape to M63, the Sunflower galaxy. It has wondrous tight spiral arms and a faint hint of floculousness. There is a 6.2 magnitude star not too far away. This galaxy is magnitude 9.12 and a size of 414” x 198”. Quite large indeed!
Edit: No image for this one.
In Canes Venatici, is a gorgeous face on spiral galaxy! NGC 5390 is by all accounts a very photoesque galaxy. It looks like M51, without the companion. It shows one spiral arm winding in one direction, while two others wind in the other. There is a faint magnitude 9.0 star on one side of the galaxy. In color, this would make a very frame-able piece of art on any wall!
Lastly, in the constellation of Lynx, is a fantastic Edge-on galaxy, UGC 4277, similar in appearance to NGC 4565. It has a dark central lane bisecting this galaxy. This magnitude 14.9 galaxy is 348” x 24” in diameter.
Faint, but imaged is very rewarding, if you like edge-on galaxies!
Enjoy this month’s EAA Challenge!
  • Bob Campbell, Ptarmigan, Jamez and 8 others like this
#2 dave85374
dave85374
  • Loc: Surprise, AZ
Posted 01 April 2022 - 10:53 AM
I found NGC2438 last week while trying to finish my Messier photo list, and yes I knew it was there for the looking.
  • M46_NGC2438_Stack40_Light_M46_8.0s_Bin1_gain200_20220323-195333_-10.0C.jpg
  • Bob Campbell, Ptarmigan, Stargazer3236 and 3 others like this
#3 Cey42
Cey42
  • Loc: Kirkland, WA
Posted 01 April 2022 - 02:59 PM
You have some tough planetaries on your list. They will be a fun challenge for me. Now I just need some clear skies.
Here is the SkySafari observing list.  Does not include Rotten Egg Nebula because I could not find it in SS.
Attached File  CN Apr22.skylist   4.66KB   17 downloads
Edited by Cey42, 01 April 2022 - 03:03 PM.
  • roelb likes this
#4 Tfer
Tfer
  • Loc: Northern Alberta, Canada
Posted 01 April 2022 - 03:51 PM
Because of work, I’m a few months ahead of you in planetary nebulae, but there’s a couple of galaxies that look VERY intriguing!
#5 MarMax
MarMax
  • Loc: SoCal
Posted 02 April 2022 - 11:18 AM
Here is an attempt at M97. Last night the SQM-L measured 17.95 and M97 was very slow to develop and I still had to stretch the heck out of it, even with 25 minutes total time. Hopefully those in some darker skies will pull much more out of it. I'm showing two images, the first "Saved exactly as seen" and the second linked with a very basic (quick and dirty 5 minute effort) post-processing in APP and Photoshop.
M97
C11, f/6.3 reducer, #93519 2" diagonal, Gerd Neumann filter drawer (UV/IF filter), ASI533MC, 15 second exposures, 25.5 minutes total, cropped and converted from PNG to JPG
M97, 15 second exposures, 25.25 minutes total,  Q&D APP and PS post-processing
EDITED to add that I started off with no dark library. I went to add the dark and there were no files. The day before I had been cleaning up the files on the laptop and must have deleted the "darks" folder. Luckily I had copied all the files from the laptop to the 2TB external drive so I was able to copy that folder back over. And I still don't know if the flat is doing anything. There is no difference I can see on the laptop with the flat applied or without.
Edited by MarMax, 02 April 2022 - 11:23 AM.
  • Bob Campbell, Ptarmigan, roelb and 4 others like this
#6 alphatripleplus
alphatripleplus
    World Controller
  • Loc: Georgia
Posted 03 April 2022 - 03:48 PM
Last night I looked at some of the galaxies on the list. Set-up was  my C8 reduced to f/3.8 (twin stacked f/6.3 reducers) and ASI290MM at high gain (300), no binning and no filters, captured with ASILive, with 7-8minute total exposures:
First up is a 8 minute exposure of NGC5390. This one could definitely do a longer total exposure:
NGC5390; 32 x 15sec
  • Bob Campbell, Ptarmigan, Jamez and 9 others like this
#7 alphatripleplus
alphatripleplus
    World Controller
  • Loc: Georgia
Posted 03 April 2022 - 03:51 PM
Next, with the same set-up is a 7 minute exposure of the nice spiral NGC2841. The dark dust lanes in the spiral arms are visible:
NGC2841; 28 x 15 sec
#8 alphatripleplus
alphatripleplus
    World Controller
  • Loc: Georgia
Posted 03 April 2022 - 03:55 PM
Last one from yesterday's session is a 7 minute exposure of the diminutive edge on spiral UGC4277 - I can just make out the dark lane across the centre of the disc. Click to zoom in.
UGC4277; 28 x 15sec
  • Bob Campbell, Ptarmigan, Jamez and 11 others like this
#9 Mark Lovik
Mark Lovik
Posted 05 April 2022 - 05:26 PM
M97
EAA+ with FWHM and Brightness filter to handle SCT corrector frosting.  Only a fraction of the live stacked frames passed thru the filtering.  You can even live stack with a hair dryer blowing on the corrector - just block the view so the frame is rejected and keep going!!!  Sometimes you just get determined ... yeah ... we can call it that.
M97 Owl Scr Stack 183frames
  • Bob Campbell, Ptarmigan, alphatripleplus and 8 others like this
#10 SchoolMaster
SchoolMaster
  • Loc: Florida
Posted 06 April 2022 - 12:46 PM
I tried that technique and ended up with 40 out of nearly 400 subs, over about an hour, while doing manual drift correction.  I have no plans to beat myself with that particular spiked club again.  I did get a decent capture though.
SVBONY 80ED, GEM28, 0.80, ZWO224MC 1.73"/px, f/5.6 at 448mm. 78F, clear, still, and very humid.
Gain 360,  15 secs x 60. Dark, Flat,
M97
15 sec x 60
NGC5390
I'm learning my first EQ mount, GEM28, and plan to use this Month's challenge as a test, and to test my camera/OTA/Reducer combinations.
  • Bob Campbell, Ptarmigan, roelb and 5 others like this
#11 Cey42
Cey42
  • Loc: Kirkland, WA
Posted 07 April 2022 - 02:43 PM
A very short night before the clouds rolled in. I did manage to view one of the challenges.
Equipment
  • Celestron 8” SCT on Celestron Advanced VX mount wtih Celestron F6.3 focal reducer
  • Darks/Flats applied
  • Bortle 7 (red zone).  Seeing OK.
  • ZWO ASI294MC, 300 gain with Optolong Pro filter
M97
75x12s=15 min.
  • Bob Campbell, Ptarmigan, alphatripleplus and 2 others like this
#12 roelb
roelb
  • Loc: Belgium, Antwerp
Posted 08 April 2022 - 10:48 AM
SVBONY 80ED, GEM28, 0.90, ZWO 224MC  68F,  clear, <5mph breeze. Image scale 1.73"/px f/5.6 at 448mm
Gain 400  15secs x 60 Dark, Flat
NGC4277 (maybe)
You have imaged:
NGC 4259/66/68/70/73/77/81
Abell 1516
IC 3153
But the intention was to look at UGC 4277
Edited by roelb, 08 April 2022 - 10:50 AM.
#13 SchoolMaster
SchoolMaster
  • Loc: Florida
Posted 08 April 2022 - 01:25 PM
You have imaged:
Abell 1516
IC 3153
DUHHHH!  Can't read my own writing in the dark :)
  • roelb and steveincolo like this
#14 SchoolMaster
SchoolMaster
  • Loc: Florida
Posted 10 April 2022 - 08:12 AM
Let's try again.
SVBONY 80ED, GEM28, 0.80, ZWO224MC image scale 1.73"/px f/5.6 at 448mm, 53F, clear, gusts up to 10mph
Gain 350, 5 secs x 60 Dark Flat, less aggressive stretch.
I'm testing and learning to use my first EQ mount.  The 'small bore' OTA is unsuited to these targets.  The C8/290M may follow later in the month, but most of these targets are accessible to me only in the Evening.  After school I'm wrecked, before school I need to sleep, so Saturday evening is my only sensible observing time.
NGC2022
NGC2392
NGC2438
  • Bob Campbell, Ptarmigan, roelb and 3 others like this
#15 SchoolMaster
SchoolMaster
  • Loc: Florida
Posted 10 April 2022 - 08:15 AM
NGC2541
15 secs x 60
15 secs x 20
#16 andrea_milanesi
andrea_milanesi
  • Loc: Milan, Italy
Posted 12 April 2022 - 12:21 PM
NGC2438 in M46. Picked yesterday @ 3/4 moon. 5sec x 100 exposure no dark no flat. First time I try EAA, I wonder what can be done without the moon.
Edited by andrea_milanesi, 12 April 2022 - 03:29 PM.
#17 steveincolo
steveincolo
  • Loc: Boulder, Colorado, US
Posted 12 April 2022 - 12:26 PM
Very nice start!  What equipment did you use?
#18 andrea_milanesi
andrea_milanesi
  • Loc: Milan, Italy
Posted 12 April 2022 - 01:49 PM
C6 Evolution with QHYII462 unfiltered; 0.63x reductor with a 0.5x reductor screwed directly on the camera for a total reduction to f/5.4. the 0.5x give a bit of distortion. Next time I'll try without the 0.5x and maybe with binning 2x2, just to see the effect on very faint object.
Gain was set to 400 in this case.
Edited by andrea_milanesi, 12 April 2022 - 01:50 PM.
  • Bob Campbell, roelb and steveincolo like this
#19 PeterAB
PeterAB
  • Loc: Southern Wisconsin, USA
Posted 13 April 2022 - 02:45 PM
I got to see a couple planetary nebula the night of April 11.   Sky was quite clear.    The moon was bright at 76%.   This reduced my naked eye limiting magnitude to about m3.2 +/-.  Seeing fair early lower in the sky, improving to good.
Meade 2080 8" SCT on the fork tracking mount.   ZWO ASI294mc in bin 1.   Sharpcap live stacked.   File size reduced.  Flats and darks applied.   Flats are still a work in progress, but, they did improve the views.
NGC 3242 (C59-Jupiter's ghost nebula)   Crop 50% (26'x18').   North up, east left.  105 seconds (7x105s).  Gain 130. IR-UV cut filter.   This view was most effected by not so great seeing low in sky close to trees and roofs.   C59 is eyepiece visible from my home.
M97 North up, east left.  53 'x 36' view.  900 seconds (15x60s).  Gain 130. IR-UV cut filter.  M97 is not eyepiece visible for my home observing location in the city.
M97 North up, east left.  53 'x 36' view.  1515 seconds (101x60s).  Gain 285. L-Extreme filter.   I had to turn up the gain a fair amount with this filter to avoid clipping the black level.    I do get more contrast on m97 with this filter.
Peter
Edited by PeterAB, 13 April 2022 - 05:58 PM.
#20 MartinMeredith
MartinMeredith
Posted 18 April 2022 - 07:41 AM
No chance to look at the PNs this month, but here's NGC 2438 from January on one of the the first outings with my ASI 290MM. I turned the saturation up further than I normally would to bring out the PN and also the contrasting stellar colours.
BTW, I read here that the PN is further away (1.9 kpc) from us than the cluster (1.5 kpc).
#21 MartinMeredith
MartinMeredith
Posted 18 April 2022 - 11:17 AM
And here's NGC 2371 captured in Jan with the ASI 290MM and last March with a Lodestar X2 mono (although at half the overall exposure).
ASI 290MM
Lodestar
The longer exposure shows the sidebands of the 'sweet wrapper' more clearly, and is a little deeper on the stellar front too.
  • Bob Campbell, Ptarmigan, roelb and 2 others like this
#22 MartinMeredith
MartinMeredith
Posted 18 April 2022 - 11:33 AM
And I also have NGC 1514 from Feb to compare with a Lodestar image from last March. This is a bit of a toughie. This time the exposures are more or less reversed, with the Lodestar getting longer. Even so, the ASI 290 image is better-defined while the Lodestar one looks washed out colour-wise. I put this down to seeing conditions (light cloud perhaps) or the altitude of the object at the time of capture.
ASI
Lodestar
#23 bmcclana
bmcclana
  • Loc: Central CT, USA
Posted 18 April 2022 - 02:50 PM
I have had only a couple clear nights in April so far, and have been doing some shake down of a new mount setup.
I picked up an Evolution Mount on the large CPC tripod to use with my 8" SCT. I am using my PlayerOne IMX462 camera with an original Optec Maxfield 0.33x reducer.  i have an ~450nm long pass filter installed next to the camera because the blue correction of this reducer isn't very good, but cutting out the far blue tightens up the stars nicely.  Once I got the alignment figured out I was getting nice GoTos and tracking.
This Setup gives me 715mm focal length at ~F3.5.  the field is small at about 0.45x0.25 degrees and 0.8"/pixel.
all the images were saved from sharpcap and cropped to reduce the rotation artifacts, more details in the gallery
M1-7 45 frames@8s
M1 7 45frames 360s Crop
NGC1501 75@8s
NGC1501 75frames 600s Crop
NGC1514 75@8s
NGC1514 75frames 600s Crop
NGC2371 12@30s (if I really stretch it, I can make out the smallest hint of the wings)
NGC2371 12frames 360s Crop
NGC2392 150@2s
NGC2392 150frames 300s Crop
NGC2841 75@4s
NGC2841 75frames 300s Crop
UGC4277 135@4s
UGC4277 135frames 540s Crop
M97 113@8s
M97 No filter 113frames 904s crop
M97 20@30s with IDAS LPS-D2.  I think the filter and the longer exposures combined to give a much better picture even though the total time was shorter. I also had a better flat and tried the new Gradient removal in Sharpcap.
M97 LPSD2 20frames 600s Crop
edit, fix a mislabeled pic of the Eskimo and remove a bonus that wasnt part of this months list.
Edited by bmcclana, 18 April 2022 - 04:29 PM.
#24 nother
nother
  • Loc: Hamburg, Germany
Posted 20 April 2022 - 06:08 AM
thanks again for this nice April list. Normally PNs are not on my observation list, so it was great fun to be "forced" to take a look on some of these :)
As the conditions were very nice last night, I was able to observe/capture every object that was not below horizion. Unluckily there were some objects not visible for me as I live 53° north.
Setup for all captures:
10" RC f/8; no reducer
ASI 533MC Pro: Gain 300, cooled to -10°C
SharpCap 4.0 with darkframe applied
EQ6 mount
M97: 77 x 8s
NGC 3242: 15 x 8s ... and captured through a tree :)
NGC 2022: below horizon
Abell 12: below horizon
NGC 2438: below horizon
NGC 2392: 14 x 8s
NGC 2346: below horizon
NGC 2440: below horizon
NGC 2371/72: 83 x 8s
NGC 1535: below horizon
NGC 1514: below horizon
NGC 1501: 32 x 8s
Calabash: below horizon
Minkowski 1-7: not in Stellarium
Minkowski 1-8 not in Stellarium
Abell 33: below horizon
Abell 34: below horizon
NGC 3583: 100 x 8s
NGC 2841: 56 x 8s
NGC 5390: 67 x 8s
UGC 4277: 48 x 8 ... and moon already rising
  • Bob Campbell, Ptarmigan, roelb and 7 others like this
#25 bmcclana
bmcclana
Posted 20 April 2022 - 09:51 AM
I setup on the other side of the house to try a couple of the southern targets.
Still using the Meade 8" with Optec 0.33x reducer riding on an Evolution mount with a PlayerOne Mars-C and an IDAS LPS-D2 filter.
My alignment/tracking wasn't quite as good tonight.
M1-8 16frames@15s
M1 8 16fx 240s Crop
NGC2346 16f@15s
NGC2346 16fx 240s Crop
Abell 33  60f@15s  This one sure is dim, I could only see a hint at 5 min, and 15 is barely pulling it out of the noise.)
Abell 33 60fx 900s
Since the other southern target were already in the trees, I switched to the IDAS NBZ to try on the Owl.  contrast is definitely even better that the LPS, but the poor tracking really shows up at the 30s exposures
M97 NBZ 30fx 900s Crop
