A couple of notes:
* The IOS application is now available in App Store. Search for "PegasusAstro Unity"
* The SkySafari NYX-101 driver unlocks the mount brake,. Make sure you ticked "Set Telescope Time and Location".
I have been playing with the IOS app and SkySafari 7 Plus this morning with the mount. I love the IOS Unity app!!!!
Thanks to the PegasusAstro team for have the star catalog and alignment star number settings in this app!
I did some further testing and found I misspoke earlier the SkySafari does unlock the brake as mentioned by EvansG. What it doesn't do is unpark the mount. However, this is not an issue for me. As my workflow goes, I have to use the Unity app to push the data to the mount and do the star alignment process which will require the mount to be unparked. After that I use Safari to align to the last star from the alignment process and am good to go.
One thing I did noticed that was missing from the mobile Unity app is the electronic assistance for the mount. This would be really helpful to use setting the pitch and roll with a tablet or phone. (maybe it will be added in a future update??)
So my workflow is now.
1. set up tripod mount and level
2. Open your tablet/phone and connect the the Nyx101 wifi hotspot.
a. Make sure the In the IP Address use the fixed IP that Pegasus Astro uses. 192.168.137.1.
b. The port number to use is 9999.
3. Open Pegasus Astro Unity program on a pc and connect to the mount.
4. Use the electronic assistance to set the pitch (latitude)
5. Do a polar alignment
6. Open the Mobile Unity app
7. Connect to the mount hotspot (the hotspot name starts with Nyx...)
8. Unpark the mount
9. Make sure track I set to sidereal.
10. Run a star alignment process in the Unity app
11. Open SkySafari on the mobile device.
12. This part will only need to be done once
a. go to Settings.
b. Select Presets.
c. add preset
d. Set the mount type to Equatorial Goto (German)
e. Set the scope type to Pegasus NYX-101.
f. Select Next for the ip settings
g. Make sure the In the IP Address use the fixed IP that Pegasus Astro uses. 192.168.137.1.
h. The port number to use is 9999.
i. Select Next for next screen.
j. Make sure the Set Telescope Time & Location is turned on. (slide button to turn on)
k. Save Preset
l. Your saved preset should be selected
m. Now close settings
13. Now connect to the mount. The DSO should match from the last star from the star alignment process.
Hope everyone is enjoying learning this mount. I really like the mount.
If there are any mistakes in this post let me know and I will correct.
Clear skies!!
Edited by astronewbster, 27 January 2023 - 06:08 PM.
