About 2 months ago I took delivery of what may well be the last LZOS 254MM F9 objective lens assembly to be imported in to the US. I had a TEC250VT F9 on order with Yuri for perhaps an early summer delivery, but dang it, Markus has a LZOS 254 F9 objective in stock along with a compatible straight through tube assembly. After a series of communications with Markus, I bit the bullet and made the order for the APM/LZOS assembly. I let my order with Yuri stand as I wanted it as a back up in case for some reason things did not work out to my liking with the LZOS objective. However, "things" have worked out very well with the LZOS objective and I recently cancelled my order with Yuri. I must say, Yuri was great to work with, professional and very understanding.
The 350 pound APM "coffin" arrived about three weeks after I placed the order. Working with Markus was a pleasure. He was professional and kept me informed at every step of the order and shipment process, including pictures too. The individual parts were all professionally boxed/crated and separately wrapped inside the main coffin (yes, assembly was required but being an ATMer I really enjoyed it). The objective came in its own stout LZOS wood case which was itself crated and then secured in yet another box and finally carefully positioned in the coffin. Uncrating of the parts and assembling them were straight forward (though my lower back takes exception to that statement).
The ~12" O.D. tube assembly is nicely done and rather light weight for its size. It has a very nice powder coat finish, simple but robust countercell for the objective and an excellent, fixed dew shield with endcap. The tail end has a slick sliding weight assembly. The backplate has three removable knobs that are very useful handles and an excellent adapter to take the FT focuser. The focuser adapter has three sets of push/pull screws to easily align the focuser with the center of the lens. The alignment plate is also threaded to take an AP 2.7" focuser but had a FT adapter (this came in handy later).
The objective cell is very robust with a thick flange on the back which holds the attachment/collimation screw sets. The objective and cell weighs in at about 55 pounds(!)
Included accessories were a 2", 80mm long extension tube, a couple of very nice preinstalled Synta style finder brackets and some drop dead beautiful, robust, mounting rings.
The total OTA weight sans rings and sliding weight system is around 95 pounds.
Attached are some pictures. Note the comparison with the scope it replaces, the TEC 200ED. The 200ED looks (and IS) small in comparison!
More later.
Jeff
Edited by Jeff B, 01 April 2022 - 11:57 AM.
