Questions:
1. Does it work on non-tracking scope (of course with very short exposures and obvious limitations)
2. What are the sensor specs: pixel size, resolution, sensor size?
3. What is the weight of the device?
Very cool project! I was looking for something like at.
Hi Artik,
1- Depends on your target and your exposure time. But the Astrowl box integrate a frame auto alignment function (like you have in Siril or other astrophoto software). However it has some limitation, especially if you have a great distance between two frames. So it can compensate tracking errors, but it won't do miracle on big distance,
2- Sony IMX462, very sensitive sensor and impressive on IR.
3- Should be around 300g (probably less) I must check.
Edited by Astrowl, 07 July 2022 - 06:30 AM.
