Cleaning Mirrors
6 replies to this topic
#1 StarWars
StarWars
    Mr. Postmaster Man
Posted 26 May 2004 - 12:29 PM
When cleaning a mirror use a cleaner which will completely evaporate...
All mirrors MUST have a protective coating!
If the mirror did not have a protective coating the reflective aluminum dust coating will oxidize and would loose it's reflectivity...a compact disc (CD) also utilizes the same type of technology..
#2 Levente
Levente
Posted 31 May 2004 - 01:28 PM
My question is simple: does the primary mirror of the Celestron 8 have protective coating on the surface?
#3 John Hoare
John Hoare
    I is who I is
Posted 31 May 2004 - 01:42 PM
All primaries need a protective coating to prevent oxidization. I don't know for absolute certain the answer to your specific question but I'd be totally astonished if it's 'no' given the reputation of C8s.
#4 bierbelly
bierbelly
Posted 31 May 2004 - 03:49 PM
Even the mirror of my MakNewt, made in the early 1960's had a protective coating on it. I'd be pretty certain that they all do.
#5 Don W
Don W
    demi-god
Posted 31 May 2004 - 04:13 PM
Yes, any aluminized surface has to have an overcoat. Otherwise it oxidizes very rapidly.
#6 StarWars
StarWars
    Mr. Postmaster Man
Posted 03 June 2004 - 01:47 AM
Good question...the mirror will have a protective coating however not sure which type of materials are used in the process..
#7 Don W
Don W
    demi-god
Posted 03 June 2004 - 07:07 PM
Usually it's silicon oxide (SiO), but they can add other more expensive coatings that have higher reflectivity.
