EAA Monthly Observing Challenge - May 2022
102 replies to this topic
#26 GoFish
GoFish
  • Loc: Wisconsin
Posted 05 May 2022 - 10:01 PM
NGC5466
ASI294MC Pro @-10C, darks+flats+dark flats applied, gain 120, no filters
Atlas mount on permanent treated wood pier, unguided
8” f/5 Orion SkyView Newtonian, EAF focuser
ASIAir Pro, saved as viewed, no post processing
Stacked 14 minutes worth of 10 second exposures. I tried and failed to bring out the reported blue in many of its stars mad.gif
  • Ptarmigan, Jamez, roelb and 10 others like this
#27 wmorrison58
wmorrison58
Posted 06 May 2022 - 08:31 AM
M5
ES127MM @ 952FL
ZWO ASI294MC Pro
Frames=68
Total Exposure=273s
Gain=450
Exposure=4.000s
Temperature=-10
Apply Flat=None
Subtract Dark=None
  • Ptarmigan, roelb, Alien Observatory and 7 others like this
#28 wmorrison58
wmorrison58
Posted 06 May 2022 - 08:40 AM
M57
ES127mm @ 952 FL
ZWO ASI294MC Pro
Frames=22
Total Exposure= 352s
Gain=450
Exposure=16.000s
Temperature=-10
Apply Flat=None
Subtract Dark=None
Edited by wmorrison58, 06 May 2022 - 09:50 AM.
  • Ptarmigan, roelb, Alien Observatory and 8 others like this
#29 wmorrison58
wmorrison58
Posted 06 May 2022 - 08:51 AM
M82
ES127mm @ 952 FL
[ZWO ASI294MC Pr
Frames=23
Total Exposure= 368s
Gain=450
Exposure=16.000s
Temperature=-10
Apply Flat=None
Subtract Dark=None
#30 wmorrison58
wmorrison58
Posted 06 May 2022 - 08:59 AM
NGC5466
ES127mm @ 952 FL
ZWO ASI294MC Pro
Frames=49
Total Exposure= 196s
Gain=450
Exposure=4.000s
Temperature=-10
Apply Flat=None
Subtract Dark=None
  • Ptarmigan, roelb, BrentKnight and 9 others like this
#31 wmorrison58
wmorrison58
Posted 06 May 2022 - 09:05 AM
NGC7023
ES127mm @ 952 FL
ZWO ASI294MC Pro
Frames= 25
Total Exposure= 400s
Gain=450
Exposure=16.000s
Temperature=-10
Apply Flat=None
Subtract Dark=None
  • Ptarmigan, russ75, Jamez and 11 others like this
#32 wmorrison58
wmorrison58
Posted 06 May 2022 - 09:23 AM
M83
ES127mm @ 952 FL
ZWO ASI294MC Pro
Frames=142
Total Exposure= 2272s
Gain=350
Exposure=16.000s
Temperature=-10
Apply Flat=None
Subtract Dark=None
  • Bob Campbell, Ptarmigan, russ75 and 11 others like this
#33 GoFish
GoFish
  • Loc: Wisconsin
Posted 06 May 2022 - 09:55 AM
M5
ES127MM @ 952FL
ZWO ASI294MC Pro
Frames=68
Total Exposure=273s
Gain=450
Exposure=4.000s
Temperature=-10
Apply Flat=None
Subtract Dark=None
Nice composition.
#34 wmorrison58
wmorrison58
Posted 06 May 2022 - 11:18 AM
Thanks Jim, Traveling right now - All darks and flats on my other computer did not think to copy over - next time. Been at battle with the noise and other artifacts of late Supposed to be clear most of weekend, hoping to get things under control a little better - HAVE A GREAT DAY!! - Wes
#35 BrentKnight
BrentKnight
  • Loc: Foley, Alabama
Posted 07 May 2022 - 04:06 PM
Capture of M57 from last evening with the C8 + ASI294MM-C + F6.3 FF/FR + UV/IR filter.  Darks, flats and dark flats.
M57 25frames 375s
15"/6' @ G:350.  Full frame Bin 1
M57 Screenshot 2022 05 07 032021
SharpCap screen grab
Tonight I'm heading to Pensacola Beach for a club outreach event.  I hope to grab M83, Omega Centauri and Centauri A.  Also check in on SN2022HRS.
  • Bob Campbell, Ptarmigan, russ75 and 12 others like this
#36 MartinMeredith
MartinMeredith
Posted 08 May 2022 - 01:55 AM
Here's some of this month's objects from last night (first session in 3 months according to the synscan hand controller...).
These are with my 8" f/4 Newt + ASI 290mm + filters, live combined LRGB. Most details on the captures apart from binning (all 2 x 2) and gain (200). Moderate seeing, partial moon.
M57
M5
NGC 5466
I turned the saturation up to enhance the contrast between the blue and yellow members.
Martin
  • Bob Campbell, Ptarmigan, Jamez and 17 others like this
#37 soulearth
soulearth
Posted 08 May 2022 - 07:54 AM
A simple little M82. I had fun taking it using the Optolong night sky filter which is passing from 650nm and in the near infrared ( 650nm - 1000nm). More near IR than visible in this image.
Software: sharpcap pro
130/650 PDS Skywatcher + EQM35
QHY 290M cooled and gain 198
Exposure : 57 frames x 20s -> 1140s
Sky : Bortle 8
M82
Image save from livestack sharpcap
Edited by soulearth, 08 May 2022 - 08:08 AM.
#38 Cfeastside
Cfeastside
Posted 08 May 2022 - 08:11 AM
finally got a chance to do some EAA last night and worked on the list a bit.  Tried to get M83 but it was behind the trees.  still having a problem getting this setup to focus properly so things still are soft.
info for the images:
c9.25 at f10 on cgx
zwo uv/ir cut filter
gain of 400
asi294mcpro
darks applied
SC 4, CPWI, NINA
resized in PS
b4/5 skies
M5 Globular
spectacular globular.  i looked at this one in my c11 last weekend visually for the first time too and it is dazziling! slight crop
31 frames at 1s ea
M5 Stack 31frames 31s resized
M57 The Ring Nebula
pretty nice.  not as large as it looked in my c11 last weekend visually.  wink.gif first time viewing this visually last weekend and last night with the eaa setup. cropped
21 frames at 15s ea
M57 Stack 21frames 315s WithDisplayStretch resized
#39 Far_Southern_Skies
Far_Southern_Skies
  • Loc: Kingston, Tasmania Australia
Posted 09 May 2022 - 07:33 PM
Hygiea
I had about an hour spare last night and thought, as a final challenge, I would try for Hygiea.
Hygiea was relatively easy to locate.  It was positioned amongst a scattering of readily identified stars, making it easy to find.
I started out thinking I would simply leave SharpCap live stacking the star field for the hour and see if Hygiea's motion was evident. Frames were 2 seconds each and a gain of 400, dark subtracted. Scope was Vixen ED103S and camera an ASI385.
For some reason that escapes me now given I am nice and warm again, I started regularly pausing the stack for short periods after the first 50 frames were stacked. That is, stack 50 frames, pause and let 50 frames drop and then repeat. Slight elongation became apparent after about 20 minutes of exposure.
The final stack attached is 827 X 2 second frames with the last frame stacked 56 minutes after the first frame.
The motion is ready apparent over the 56 minutes. If clear tonight, I'll try for a single image to confirm Hygiea's motion over the 24 hours.
  • Hygiea_2022-05-09_ED103S_ASI385_Stack_subs2.0s_frames827_exposure1654s_Gain400.png
#40 Far_Southern_Skies
Far_Southern_Skies
Posted 09 May 2022 - 10:47 PM
M83 - Southern Pinwheel
Another capture from last night.
Vixen ED103S_ASI385_subs8.0s_frames75_exposure600s_Gain400. Crop and downsize to fit here.
  • M83_2022-05-09_ED103S_ASI385_Stack_subs8.0s_frames75_exposure600s_Gain400.png
  • Bob Campbell, Ptarmigan, russ75 and 13 others like this
#41 Straight on til morning
  • Loc: Auckland, New Zealand
Posted 10 May 2022 - 05:50 AM
Southern Pinwheel. About 4 mins exposure. Had a nice long stack going and then the live stacking crashed so missed out on posting a longer EAA exposure. Having some mount challenges as have had to move my scope placement due to renovations and haven't quite got it set up properly.
C6 at 1000mm, asi462 bin2, gain 90, 10s subs
Light Stack 26frames  ASILive 10sec Bin2 20.1C gain90 2022 05 08 201648   M83   Southern Pinwheel
Hygiea was a lot easier than I expected, with the help of my eVscope. The movement is clearly visible.
eVscope 20220510 085744   Hygiea
I've been observing asteroids on multiple nights this week for the Unistellar Citizen Science programs and they move a heck of a lot faster than Hygiea - they move visibly with each 4s sub.
Edited by Straight on til morning, 10 May 2022 - 05:54 AM.
  • Bob Campbell, Ptarmigan, russ75 and 14 others like this
#42 SchoolMaster
SchoolMaster
  • Loc: Florida
Posted 10 May 2022 - 07:58 AM
Picked these up in the middle of other things.
C8, GEM28, 0.63, ZWO 294MC, image scale 0.70"/px f/6.3 at 1280mm.  Clear, 68F, 10mph gust, swirl.  Use the 80cm dew strip for the first time.  The combination of swirling gusts, dew shield and big OTA caused issues at times.
Gain 350, mostly 15 or 45 x 20 secs.  Dark (75F) Flat.
M82
45 x 20 secs
NGC5466
15 x 20 secs
NGC7023
45 x 20 secs
Wrestling with better flats.
Edited by SchoolMaster, 10 May 2022 - 07:59 AM.
  • Bob Campbell, Ptarmigan, russ75 and 10 others like this
#43 rnyboy
rnyboy
  • Loc: Rochester, NY (Bortle 7/8)
Posted 10 May 2022 - 09:24 AM
NGC 7023 EAA taken a couple of nights ago with 6se, f/3.3, 385mc (3s exps using dark correction, 60min total exp, 400gain), cropped to remove majority of the vignetting and field rotation...
Edited by rnyboy, 10 May 2022 - 09:27 AM.
#44 rnyboy
rnyboy
Posted 10 May 2022 - 09:39 AM
NGC 7023 (Snow Globe cluster) from a week and a half ago.  6se, f/6.3, 294mc with CLS filter (5s exp w/dark correction, 6 min total, 425 gain).  First time out with the 294mc and wasn't really looking too long at anything that night.  Has more vignetting than I was actually hoping for but also a whopping increase in fov over my 385mc.  (I really need to start using flats but they seem to be considerably more of a PITA to obtain over the simple darks)...
Edited by rnyboy, 10 May 2022 - 09:48 AM.
  • Bob Campbell, Ptarmigan, russ75 and 8 others like this
#45 Bob_Stan
Bob_Stan
  • Loc: Northeast
Posted 10 May 2022 - 10:36 PM
NGC 5466
C-11 @ 2794
ZWO ASI294MC Pro
Frames=12
Total Exposure=720s
Gain=200
Exposure=60.000s
Temperature=-10
#46 Far_Southern_Skies
Far_Southern_Skies
Posted 10 May 2022 - 10:58 PM
Hygiea 24 hours apart
There was lot of high level haze last night but I still managed a capture of Hygiea to show it's movement over 24 hours.
My 56 minute time lapse the night before - see my earlier post #39:
Hygiea_2022-05-09_ED103S_ASI385_Stack_subs2.0s_frames827_exposure1654s_Gain400 V3.png
My short stack last night - ED103S_ASI385_SharpCap_2.0s subs_165 frames_330s total exposure_Gain400:
Hygiea_2022-05-10_ED103S_ASI385_SharpCap_2.0s subs_165 frames_330s total exposure_Gain400 V1.png
  • Bob Campbell, Ptarmigan, russ75 and 7 others like this
#47 Bob_Stan
Bob_Stan
  • Loc: Northeast
Posted 10 May 2022 - 11:09 PM
A very unusual 4th usable night in a row!
M 57
C-11 @ 2794
ZWO ASI294MC Pro
Frames=20
Total Exposure=300s
Gain=200
Exposure=15s
Temperature=-10C
  • Bob Campbell, Ptarmigan, Jamez and 10 others like this
#48 BrentKnight
BrentKnight
Posted 10 May 2022 - 11:24 PM
M83 (Southern Pinwheel Galaxy)
Celestron C8 + ASI294MM-Pro + Celestron F6.3 FF/FR + UV/IR Filter.
15"/40' @ G:350.  Flats and dark flats applied.  Captured as seen with SharpCap, no cropping.
M83 164frames 2460s
  • Bob Campbell, Ptarmigan, roelb and 9 others like this
#49 SchoolMaster
SchoolMaster
  • Loc: Florida
Posted 11 May 2022 - 02:04 PM
C8, GEM28, 0.63, ZWO 294MC, image scale 0.7"/px  f/6.3 at 1280mm  63F, clear, still, low humidity.
Gain 350, 45 x 20 secs, Dark, Flat
NGC40
Captured as a 1400 pixel square ROI.  Better focus needed.
  • Bob Campbell, Ptarmigan, roelb and 7 others like this
#50 SchoolMaster
SchoolMaster
  • Loc: Florida
Posted 11 May 2022 - 02:05 PM
NGC7023
  • Bob Campbell, Ptarmigan, roelb and 4 others like this
