6" reflector- Does anyone know what this is?
35 replies to this topic
#26 Maxtrixbass
Maxtrixbass
  • Loc: Camano Island, WA
Posted 04 May 2022 - 10:21 AM
ID confirmed. Nice call Robert!
"Hi William,
Yes that is one of our 6" F4 OTA which we made about 300 and it was made in the late 70s. It looks like it is in good shape.
Good luck,
Paul T. Jones, Owner/Optician
Star Instruments"
Having spent more time on the collimation I must say the view is quite good, superb really. The outer edge does show coma, but the central 7/8ths is impressive for such a fast scope.
Edited by Maxtrixbass, 04 May 2022 - 10:22 AM.
  • tim53, clamchip, steve t and 3 others like this
#27 CHASLX200
CHASLX200
  • Loc: Tampa area Florida
Posted 04 May 2022 - 10:49 AM
Odd that mirror does not have the center bolt holding it in place.
#28 Maxtrixbass
Maxtrixbass
Posted 06 May 2022 - 08:11 PM
Well, I beefed up the probably homemade rings, put a 2" focuser on it, spent some time getting it properly collminated, inserted  a coma corrector (a basic Apertura I had on hand), put in an eyepiece and later an aps-c sensor camera. Completely stunning. There is some softness on the images in one corner  (tilt?), but for a scope this fast its surprisingly sharp across the frame. Visually there is some softness around the edges even with the CC, but one would be hard pressed to guess this as f/3.8 .
The whole setup even with the new larger focuser and heavier eyepieces/camera really isn't that heavy. Perhaps some of that is the fiberglass tube. The primary is certainly on the thick side.
The CG4 mount seems to handle it no problem.
Now to get a break in the endless clouds....
Edited by Maxtrixbass, 06 May 2022 - 08:12 PM.
  • Paul Hyndman, clamchip, steve t and 7 others like this
#29 deSitter
deSitter
    Still in Old School
Posted 07 May 2022 - 08:07 AM
Softness in one corner - definitely collimation. At f/4 the allowed error is about a millimeter. I have tweaked my collimation by making the coma even around the edges. You need an adjustable coma corrector - a Paracorr. I have come to consider my f/4.5 as a catadioptric telescope.
-drl
Edited by deSitter, 07 May 2022 - 08:19 AM.
  • steve t and Maxtrixbass like this
#30 Maxtrixbass
Maxtrixbass
Posted 07 May 2022 - 09:52 AM
It may be beyond my abilities as it is really close, although I do plan to keep trying. Pic attached (although the detail is somewhat lost at this reduction). These houses are about 2 miles away. I won't bias a response by saying which corner I find soft..  I rotated the camera for the lower left water corner to expose detail, but it looks pretty good.
If I go with my 4/3rds QHY I really think the image would be crisp to the edges. I guess I could always crop the DSLR aps-c, but again, for an F/3.8 scope with a pretty basic CC I find the results quite good.
I found binoculars at Goodwill years ago, leather case, Japanese made, maybe from the 60s (?). The view through those is similar to this scope. Its rather hard to describe, crisp, almost 3d.
  • steve t likes this
#31 deSitter
deSitter
    Still in Old School
Posted 07 May 2022 - 10:02 AM
Can't tell from such a heterogeneous image, but the upper right appears unfocused, which could be field curvature. Need point sources to identify coma.
-drl
  • Maxtrixbass likes this
#32 Maxtrixbass
Maxtrixbass
Posted 07 May 2022 - 10:49 AM
-drl
Agreed.
Weather=cloudy/rain until the end of time. Am looking forward to an actual star image.
#33 Maxtrixbass
Maxtrixbass
Posted 25 May 2022 - 10:28 AM
As a follow up..  I'm pleased with the performance of the scope and it promises some good imaging. The collimation, including secondary offset (as mentioned) is really touchy in large part due to the fast optics and in part due to the overall resolution (it really shows everything with little fudge factor) . Overall a really great instrument.
First light image here:
https://www.astrobin.com/k26via/
I'm using a GSO coma corrector which is adequate.  Something a bit better would likely do a better job, but at this point I can either crop it down to a 4/3rds sensor size and/or just correct some of the abberation in post processing.
Edited by Maxtrixbass, 25 May 2022 - 10:34 AM.
  • Paul Hyndman, tim53 and steve t like this
#34 tim53
tim53
  • Loc: Highland Park, CA
Posted 25 May 2022 - 12:19 PM
That’s a keeper!
#35 Maxtrixbass
Maxtrixbass
Posted 21 June 2022 - 09:14 AM
As a follow up..
I decided to get a Sharpstar .95 coma corrector. Finally a brief break in the clouds, so here is a star test.  Overall I am very pleased.  A tiny bit of abberation/coma in the corners of the APS-C sensor, but I can either crop it to to 4/3rds or (more likely)
correct in post processing. I consider it a success especially since the Sharpstar reduces the scope to F/3.6.
Full spectrum 500d, 10 seconds. Pixel scale 1.7 arc seconds/pixel.
Edited by Maxtrixbass, 21 June 2022 - 09:20 AM.
#36 Maxtrixbass
Maxtrixbass
Posted 21 June 2022 - 09:16 AM
Pixel peeping the corners. Oddly, the corners aren't totally consistent, but the variation is rather minimal.
  • steve t and MisterDan like this
