Mounting a deforked ETX90
4 replies to this topic
#1 FNR-dk
FNR-dk
  • Loc: Denmark
Posted 07 May 2022 - 05:04 PM
Can a deforked ETX90 OTA be mounted on, e.g., a Skywatcher AZ-GTI Wifi Head? Is it possible to get some kind of bracket or tube rings that fit the ETX90?
Finn R, Holte, Denmark
  • LU1AR likes this
#2 LU1AR
LU1AR
Posted 18 May 2022 - 01:48 PM
¡You will have the best of both worlds!. I used both 1/4" nuts from the base of the OTA, and attached a rail that allows me to use it on a GEM mount (EQ2) that I share with a refractor.
The CG falls just right, where the plastic part ends.
It is a good opportunity to put a bit of rubber foam inside the troat under the tube -where the two 1/4" screws are inserted- since light enters there when we look at the Sun, the Moon or Jupiter when we are taking photos, and loses contrast.
Regards.
Edgardo
#3 RedLionNJ
RedLionNJ
  • Loc: Red Lion, NJ, USA
Posted 18 May 2022 - 09:58 PM
I don't have pictures at hand to demonstrate right now, but I do the same as Edgardo (above) with both my ETX90 and ETX125. I have a Losmandy rail which I can mount either to, with a 1/4 x 20 screw.
Then I slide the rail into the saddle on my GEM and I'm good to go!
#4 tommyboy
tommyboy
Posted 22 March 2024 - 08:36 AM
What ring did you use to attach the dovetail? My OTA measures 103mm OD.
Edited by tommyboy, 22 March 2024 - 08:42 AM.
#5 6642
6642
  • Loc: France
Posted 28 March 2024 - 04:44 AM
It’s a really versatile tube
Easy to mount with a Vixen dovetail on any stand
