OK... only two entries... but I'll bite.
Docter Nobilem 15x60 B/GA
Exit Pupil: 4mm
Eye Relief: 15mm
TFOV: 4.1°
AFOV: 61.5°
Weight: 3.8 lb
These will always be my favorites. I've had them for twenty-one years, and as far as I'm concerened, they're heirlooms. Whether I'm stepping outside for a thirty-minute sky-check, or spending the night doing AP, these are what I grab first. Nothing else in my little binocular arsenal comes close. Tack sharp edge to edge, wonderful wide TFOV and AFOV, and exactly enough eye-relief to allow me to see the entire FOV with my fairly mild eyeglass prescription. Using standard "bracing" techniques, I can hand-hold them completely effectively... but if I'm going to be out with them for longer than half an hour, I prefer to mount them on the Bosch tripod. And at 15X, daytime hand-held spotting and following of the local hawks and vultures enjoying the nearby late-morning thermals -- and the constant raven vs red-tail wars -- is a total thrill.
APM MS 25x100 ED
Exit pupil: 4mm
Eye relief: 16mm
TFOV: 2.7°
AFOV: 67.5°
Weight: 9.4 lb
I did have a pair of Oberwerk 20x80 Deluxe IIIs for a while, which I thought were pretty good... being reasonably sharp and moderately-well color-corrected, but only within in the central 40% or so of their FOV. As such, in looking to scale up to some 25x100s, I assumed that the Oberwerk 25x100 Deluxe model would be optically no different than the 20x80s, and I was hoping for a significant improvement in both of those areas, without having to spend $2,000+ to get there.
Happily -- due to their ED glass -- I found the APM MS 25x100 EDs to be far superior to the Oberwerks, both in sharpness and color-correction -- so much so, that I quickly stopped using the Oberwerks at all, and ultimatey sold them. M42, the Pleiades, the double cluster, and the like, are spectacular in the APMs' wide AFOV. M31 fills the FOV, and its dark lanes are apparent in my 20.0 MPSAS skies. And at 25X and a 2.7° FOV, the Moon is so much larger than it was through the 20x80s. For the first time ever, in a pair of binocuars, I was able to discern actual "fine" detail in the craters along the lunar terminator. And my eyes detect no chromatic aberation in the APMs at all; no yellow or purple fringe around the edge of the Moon whatsoever.
Observing with them mounted on the Farpoint parallelogram/Oberwerk TR3 combination is pure, effortless joy. And of course, having gotten them two years ago, at their 2020 price of $970, didn't hurt.
I'd love to find a detailed one-on-one comparison between these and the Oby 25x100 Deluxes.
