What is a normal noisy/hot pixel behavior for a used Canon 6D?
32 replies to this topic
#26 piaras
piaras
  • Loc: Niagara Region
Posted 14 May 2022 - 08:15 AM
The more lights you take, the signal swamps the noise. Here is an example of over 150 lights taken with my 6D before I switched to the RA, at 30-60 seconds and ISO 800 and 1600. This photo was taken with no darks, bias nor flats. I should of taken a set of flats for the dust motes.
Pierre
Edited by piaras, 14 May 2022 - 08:48 AM.
  • BPoletti likes this
#27 vidrazor
vidrazor
  • Loc: North Bergen, NJ
Posted 14 May 2022 - 08:38 AM
I appreciate the advice guys, but like I said, I have a while to wait for my OTA. I'll look at more reliable sources for canon 6d's, and I am also looking at used Nikon d600's or other full frame cameras with good low light ISO.
What makes you think you need a full frame sensor anyway? The vast majority of astro images are shot with APS-C and even smaller sensors. You don't need a large sensor to mitigate noise, you need time. You need lots of subs, especially if you're shooting in a high Bortle location. Below is only 3 hour's worth of the Cygnus Loop shot in Bortle 9 with a full frame D600 on an AT60ED. Not too impressive, right? But hey, it's a full frame sensor, no? It looks like crap because I didn't shoot enough time, and then I proceeded to pull hens teeth LOL. I would've needed about 10-15 hour's worth of time (in Bortle 9) to get this right. This was a project I had started but unfortunately could not finish at the time, I'll try it again next fall.
So really, don't get too hung up on having a full frame sensor to shoot astro. An APS-C based camera will allow you access to more scopes that will vignette significantly on a full frame sensor as well. But you already have the 6D, you could just roll with it when you get your scope.
Edited by vidrazor, 14 May 2022 - 10:32 AM.
#28 asanmax
asanmax
    Vendor - DSLR Modifications
  • Loc: Vancouver BC
Posted 14 May 2022 - 11:35 AM
Very good point considering most of the scopes don't have an image circle large enough to cover a full frame sensor with a nice and flat image.
#29 piaras
piaras
Posted 14 May 2022 - 01:34 PM
Mostly I use my RA day and night. Also when doing photos with prime lenses on the larger targets.
Pierre
#30 zernikepolynomial
zernikepolynomial
Posted 15 May 2022 - 04:40 AM
Pierre
It completely depends on the telescope and guiding when determining what you can get away with.
#31 zernikepolynomial
zernikepolynomial
Posted 15 May 2022 - 04:43 AM
I never said you need a full frame camera to mitigate noise. I think we are getting into territory that is better discussed in its own thread.
#32 zernikepolynomial
zernikepolynomial
Posted 15 May 2022 - 04:44 AM
There are many scopes that do have an image circle large enough to cover a full frame sensor and remain flat. Also, discussion for another thread.
#33 zernikepolynomial
zernikepolynomial
Posted 15 May 2022 - 05:09 AM
Going to check the voltage on my battery. Got another tip in a different thread I created.
