All,
I am currently serving as President of my local Astronomy club. We have an aging 16" f/8 Cave-Astrola reflector that we just repaired the tracking drive on. It works now, but it's still showing its age.
What I mean to say is that it's.. limited. It's not a modern "go-to" scope, it's visual-use only since it can't achieve focus using a camera and it big & heavy. People have to climb a ladder and steady themselves at the eyepiece to look at objects which means it's unusable for the elderly and the wheelchair-bound. It's pretty badly scuffed up and it becomes a giant windsock whenever a light breeze kicks up.
There are some members of our board who seem to be of the opinion that we should leave the Cave alone and just let it do what it does best.. show nice images of the moon & planets to the interested public. My concern is that the old Cave isn't turning out the public like it used to. People seem to be (understandably) more fascinated with the EAA & astrophotography folks than with traditional viewing.
I have in mind a modernization project for our old scope, but before I put it to our board members, I'd like to hear your input.
Several of our club members (myself included) have really gotten into EAA and when we first started experimenting with doing EAA using the Cave, we.. failed. We learned that the camera could not achieve focus without either moving the focuser & secondary mirror assembly closer to the primary mirror by a few inches or moving the primary mirror forward in the tube by a similar amount.
I did some more research on this issue of focus distance in Newtonians and I came across an intriguing post that suggests a way of making that distance adjustable. When I proposed making a similar change to allow for EAA a couple years ago, I got some pushback about it on the grounds that it would complicate visual use of the scope (people would have to use an extension tube on the focuser for visual use). I suspect it was more a case of old folks not wanting things to change.
Since that time, EAA has become more popular and the old-timer's objections seem to have faded a bit, but there still seems to be a strong reluctance to alter the Cave.
My proposal is to transform our old Cave reflector into an open-tube design using plywood rings and aluminum struts that would allow the focuser and secondary mirror assembly to slide back and forth on the struts to accommodate both visual and EAA uses. My proposal would solve the following problems:
1. No tube. No more windsock behavior.
2. EAA! Images could be displayed on a monitor for better accessibility
3. Easily convertible back to visual use
4. More modern, more capable
5. We could broadcast our images
The possible downsides being:
1. More of a challenge to balance
2. More frequent cleaning would be required
3. Possible dewing issues?
Opinions? Has anyone attempted a rebuild like this?
Edited by ajkrishock, 10 May 2022 - 09:12 AM.
