So i'm trying to get this thing set up for some astrophotography in the field at our dark sky site outside Milford Utah. (Bortle 2!). I'll be going there on the 29th through the 5th of July. I want to take the Meade because the mount only needs 6 AA batteries, and my cameras can also run on their internal batteries, and I can control them via an ipad or my Mac laptop.
So I need:
A piggyback camera bracket - can't seem to find one online. Should be same as the 8" SCT, but I don't know where to look for that either.
Tube weight set - ordered one for the 8" SCT, as I already have the bar mounted to the OTA, but no weights.
Focal reducer - I have a Meade one, but it's at Cosmic Acres. I should just put it in my camera case.
Firewire to Thunderbolt adapter - for my Pt Grey firewire cameras and THIS mac laptop (a 2012, first without the firewire port, but has Astro IIDC on it that I used to use for autoguiding with a GPUSB). Ordered the adapter just now.
But for autoguiding - the LX50 mount has an ST4 port, so I assume it'll work with the GPUSB connected to the laptop. But what about something like the (expensive) MGEN 3? It might be nice not to have it tethered to anything but the mount.
Guidescope - I will have to adapt whatever I used for a guidescope. Should I just buy one of the modern ones that are basically finders with camera adapters (and mounting hardware)? Or should I adapt my 3" f/5 Jaegers OTA (below) to the Meade?
Dovetail plate? - I'd probably look for a Losmandy D style plate and put it on top. I suppose I could use a camera bracket to fit the dovetail plate. I could also make my own plate, but probably more time than it'd be worth in labor savings.
3" Jaegers:
