Patrick, that's a dramatic improvement. The diagonal mirror is much closer to focuser center.
Stop for a second and study your third image. You can clearly see the primary reflection is a little "high" in the diagonal. At this point, a neat trick I learned was to rotate the diagonal so the primary reflection is centered on the diagonal long axis. To my way of thinking, doing so will give you better rotation than eyeball rounding, and doing so bring the single screw in line with the focuser onto play during tilt alignment of the focuser axis/diagonal mirror. There are other benefits, too, but we can discuss those later.
But first, we have to finish step one for secondary placement and rotation. You're at the point you should be able to get a little better diagonal centering by using those same two L and R screws to nudge the diagonal "up" or "down" and the center bolt "left" or "right" (toward or away from the primary). Once you get good centering of the diagonal, then rotate as described above. Then you're ready for step to aligning the focuser axis.
Much better! You may not have to tilt and shim the focuser after all.
I am curious, though, because focused all the way down your diagonal mirror looks to be about the same size or smaller than the primary reflection. When your focused all the way down, a properly sized diagonal should appear larger than the primary reflection. As you focus outward, the apparent diameter of the distant primary mirror will remain pretty much the same size. However, the apparent diameter of the nearby diagonal will appear to become smaller. Thus, at some point, the entire primary reflection will appear larger than the diagonal. But that should happen around mid focuser travel beyond the focal plane, not when you're focused all the way down.
Well see, though, once you center and rotate the diagonal mirror. (rotation will center the primary reflection on the diagonal *major* axis, that single screw in line with the focuser will center the primary reflection on the diagonal *minor* axis). We still need some way to see the focuser axis, like a cross hair, but you'll be close to collimation.
Edited by Asbytec, 31 May 2022 - 10:11 AM.
