When people think of achromats and talk about secondary color, they are talking about the on-axis variation of focus with wavelength. Achromats are generally designed to bring blue (F line) and red (C line) to the same focus. The green will focus closest to the lens and when our eye, which is most sensitive in green, says the view is focused, the blue and red ends of the spectrum will be out of focus. This, however, is rarely visible at low powers and large exit pupils, it requires relatively high magnifications to make it visible to the eye.
What people usually notice is lateral color from the eyepiece. It's a variation of magnification with wavelength. If you move the bright Moon to the edge of the field, almost going out of the field, you'll see fringing from the color magnified the most. If you bright the bright edge of the Moon just into the field, you'll see the color magnified the least. With the high contrast between the dark sky and the Moon's limb, few eyepiece's are free of lateral color, although it is limited by the narrow apparent view of many binocular eyepieces.
Clear skies, Alan
