Just came off an ASI183MC Pro OSC and finally got my 1st mono cam an ASI294MM Pro.
I took some test shot at M3 with an L filter yesterday at 120s (bin2) and found that while it captured quite a lot of start, the image look kinda over exposed (not sure if this is really the right term to use) and also captured a lot of LP.
This is essentially the same exposure setting I was using on my OSC. Only difference was I was using an Opteron L-Pro Broadband Filter (Bin1).
Couple of questions here:
1. Should I be dialing back my exposure and just capture more subs? Or should I just continue with 120s and process out the gradients?
2. With the 294MM Pro I can choose between Bin 1 or Bin 2. When I take my calibration frames do I also need to take them in Bin 1 and Bin 2? Or does it not matter?
3. I understand there is a 4:1:1:1 ratio for LRGB imaging. Can I assume that the ratios refer to the number of subs and not exposure? Eg. for every 1 R,G or B sub, I need to capture 4 L sub.
Would greatly appreciate any other tips & tricks or information which you think would be useful for a newbie like myself. Thanks in advance for the guidance.
Edited by Snakey93, 18 May 2022 - 09:02 PM.
