Unihedron Sky Quality Meter with Lens - Narrow Field of View
Astrometry Equipment Observing Observing Report Visual Video Astronomy
13 replies to this topic
#1 arshadwm
arshadwm
  • Loc: Houston
Posted 22 May 2022 - 09:53 AM
Please advise about
this is a sky quality meter. Is it worth buying this ?
#2 AstroBrett
AstroBrett
Posted 22 May 2022 - 10:19 AM
I use mine extensively. It is one of my most important tools for determining sky brightness. I consider it one of the best investments I have made.
Brett
  • havasman, rhaskins and B 26354 like this
#3 havasman
havasman
  • Loc: Dallas, Texas
Posted 22 May 2022 - 10:30 AM
Yes, that is the one you want. + everything Brett said.
#4 B 26354
B 26354
  • Loc: Southern California semi-desert (NELM mag 5.3)
Posted 22 May 2022 - 10:38 AM
Totally agree with Brett & havasman. I use mine every time I'm out.
#5 Rich V.
Rich V.
Posted 22 May 2022 - 10:47 AM
I'm glad I have one; it's a useful tool.
While two different SQM-L units used side by side may give slightly different readings, they're close enough for my purposes.  My eyes can see that conditions change by the hour over the course of the night, but it's nice to be able to verify and quantify what I'm seeing.
Rich
  • B 26354 likes this
#6 Jon Isaacs
That is the SQM-L
Is it new or used?  I'd be reluctant to purchase a used SQM-L, they're a calibrated instrument and factory new is best.
I bought the SQM-L first, about 5 years ago. My thinking was I could measure regions of the sky and add them up. And I can. But the SQM-L varies depending on exactly where it's pointed and takes time to settle down. And it's not so easy to compare reading with other amateurs.
I bought a SQM a couple of years ago and I use it for my site readings. It's a one shot reading, it's settles more quickly and it's easier to compare with others. I mostly use the SQM-L to get an idea of the sky in the local region. I'll hold the meter against the upper cage of a Dob so the SQM-L is pointed where the scope is pointed.
#7 arshadwm
arshadwm
  • Loc: Houston
Posted 22 May 2022 - 07:19 PM
Thank You all. Should I buy narrow or wide angle ?
#8 Jon Isaacs
Posted 22 May 2022 - 08:20 PM
I personally prefer the Wide Angle as I wrote above.
#9 treadmarks
treadmarks
  • Loc: Boston MA
Posted 22 May 2022 - 08:53 PM
The advice I've heard on this is that if you're planning to use this in areas with lots of lights, get the SQM-L. The wide angle version could pick up those lights and distort its readings whereas the SQM-L will do more like a spot reading of what you're pointing at, preferably the sky.
#10 Ihtegla Sar
Ihtegla Sar
  • Loc: Pacific Northwest
Posted 22 May 2022 - 10:17 PM
SQM v SQML? It depends on what you want it for. To compare overall brightness of a site with your online friends or just to get an average reading for a site in one shot, get the regular version SQM. If you want to check how dark it is in a particular area of the sky you are working, get the SQML.
I chose the latter, since I can always take a number of readings in different directions if I want to get an idea what the average darkness is across the sky but more often I like to know how dark it is in the specific area I am pointing my telescope, which is something the SQM cannot do.
#11 arshadwm
arshadwm
  • Loc: Houston
Posted 26 May 2022 - 05:13 PM
Thank You all. They have three model and I want narrow band. Which one should I buy
nihedron catalog
Sky Quality Meter
$138.00
Sky Quality Meter-L
$155.00
Sky Quality Meter-LU
$218.00
#12 Ihtegla Sar
Ihtegla Sar
Posted 26 May 2022 - 06:13 PM
nihedron catalog
Sky Quality Meter
$138.00
Sky Quality Meter-L
$155.00
$218.00
This one (commonly referred to as SQML) is the version with the narrow field of view:
Sky Quality Meter-L
$155.00
The one that costs $218 has a USB connection, so only get that one if you want to set it up to interface with a computer for automated use, at an observatory or something like that.
#13 phototech
phototech
  • Loc: Sydney, Australia
Posted 29 May 2022 - 01:39 AM
I have the LU and log SQM every 15minutes to a file. I’ve been able to look back over time to see if it’s getting lighter
Also, imaging programs can be told to add the current SQM if you’re are constantly reading it say every 15minutes, to the file name. That will give you an idea of images taken at the darkest time.
The LU doesn’t have a display so you need a computer to read the value
All unihedrin devices are supposed to be calibrated
#14 airbleeder
airbleeder
  • Loc: Powder Springs, Georgia
Posted 29 May 2022 - 08:21 AM
  I've had a SQML for 3 or 4 years but used it maybe 5 times, less than 10 for sure.  My eyesight has deteriorated but not enough that I can't see when the sky is brighter.
Also tagged with one or more of these keywords: Astrometry, Equipment, Observing, Observing Report, Visual, Video Astronomy
