I wasn't going to post this, but after much consideration it deserves it. This is undoutably my most used scope, it's not as fancy or as capable as most of the scopes posted but it's earned it's moment. My lowly Towa 30-90x60mm variable mag grab n go, dead simple to use, no need for an EP case. The optical train with helical zoom is way better quality than the "click stop" pull out version of the 5V-TE and other clones.
The downsides are, the tripod is minimal but works well enough and being straight through i have been sat on the floor to get zenith views of the night sky. The 30-90x view is crystal clear through all mags and works amazingly well, zero cooldown time and while CA is present it's minimal compared to the 5v-te and only obvious on bright stuff. The scope gets almost as much use as my 10x50 bino's as i regularly use it while other scopes are cooling down. Not an all time classic or even desirable but simple and easy to use, this is the hammer in my astro toolbox
