I have a Oberwerk BT-100 and love it. Here is my eyepiece selection.
Oberwerk 7mm (70° AFOV) 80x, it works great for lunar closeups and viewing the planets.
10mm - Orion Ultra Flat Field (65 AFOV°) 56x, it is also good for lunar and planets, it’s easier to focus than the 7mm
14mm - Oberwerk (70° AFOV) 40x, great for observing just about everything with its wide FOV
18mm - Orion Ultra Flat Field (65° AFOV) 31x, I don’t use this often
25mm - Celestron X-Cel LX (60° AFOV) 22x, great for wide FOV
When I first got into this I thought magnification, magnification, magnification. But when it comes down to it, these binoculars are really great for DSO‘s, and magnification doesn’t help. For planets, the 7 mm is going to be about as good as it gets, you could probably bump it to 5 mm and get a little larger view but the planets are not gonna be that big. My observing has shifted since I bought mine and I find myself more content searching out open clusters and globular clusters. I have found so many of these with my BT. I purchased the red dot finder scope that Oberwerk sells. With that I can find anything I see in the sky in a matter of seconds. A friend of mine has the Orion BT-72, my red dot finder does not fit on his, but Orion has two threaded holes on the top of the handle, he bought a regular red dot that that line up with the holes on top of the handle. Before I had the red dot finder I was always over shooting either too high or too low.
Back to eyepieces. These days I use my 14 mm for most observing. I switch over to the 25 mm when I want to do some general sky surfing because of the wider field of view. And once in a while I pull out the 7 mm to look at the moon. I will do the same when the planets come out. So if you’re on a tight budget, I think a 7 mm, 14 mm and a 25 mm would be fine. They don’t have to be those exact sizes but something close. Anyway just my two cents being a happy owner have a great astronomy tool. I also bought a Celestron Evolution eight Telescope. And I really like it because of the larger views you get, But it will never replace my BT’s. I think with the two instruments I can find everything reasonably available in my not so good skies.
I hope this helps you not waste money on needless expensive eyepieces.
Edited by Dpasqa, 05 June 2022 - 11:06 AM.
