The Pentax 10mm XW is a superb eyepiece, one must say. Pinpoint sharp to the edge of the field, amazing ergonomics, a joy to use.
Agreed, I just picked up a pair of those yesterday. I must say, I like them even better than the Pentax 7mm XW's (which I have been super impressed with). All four Pentax XW eyepieces are essentially perfect, with no hint of any quality control issues and appear perfectly concentric. They blow the quality of the Oberwerk eyepieces out of the water and make me wish I had never believed the advertising rhetoric claiming that Oberwerk eyepieces were the "special sauce" that made the binoculars what they were. They are not even comparable really.
And it's not just the higher quality control, tighter manufacturing tolerances and better coatings that make the Pentax eyepieces stand out above the shoddy manufacturing of the Oberwerk eyepieces, it's that the design of the Pentax eyepieces seem to be tailor made for the BT-100XL while the highly hyped Oberwerk eyepieces I bought with the binoculars as additional accessories are seemingly designed for a completely different application. Which is odd considering how they are marketed. They are not parfocal with the standard 14mm eyepieces included with the BT-100XL while all the Pentax XW's are parfocal with one another. As you have already informed us, the diameter of the bases of the Pentax XW's are compatible with the diameter of the locking ring on the binoculars while the Oberwerk 7mm and 22mm are too large making them feel more awkward than a vegan in a butcher shop. Finally, the 14mm eyepieces that come standard with the BT are vastly lighter than the 7mm and 22 mm Oberwerk options which necessitates rebalancing the mount when switching between. All the 1.25" Pentax XW's have managed to keep the weight in the same ballpark which means re-balancing is not necessary when changing eyepieces.
I can see offering a bargain basement set of eyepieces with the scope to keep budget orientated buyers happy, but the base diameter should at least be designed such that they seem like they are compatible with the instrument. Useability matters. Also, the lens elements inside the eyepieces must be held approximately concentric to avoid collimation issues that can seriously detract from the useability of the binoculars. This is something that anyone who sells eyepieces in pairs for binocular use should account for even if low price is one of your selling points. Service matters too. They shouldn't tell their customers who are having issues "they are within spec", everything's fine, and send them back to the customer to deal with. In other words, if you buy a binocular telescope, don't cheap out on eyepieces, it's not worth it! The Pentax eyepieces are exquisitely designed and made to high tolerances. It's almost like Pentax actually knows a thing or two about manufacturing with precision and they are more compatible with the interface of the BT-100XL than the ones offered by Oberwerk themselves!
Thanks to you, Fiske, for your Pentax XW recommendation, I can finally enjoy using my instrument, after a year of frustration and wasting my time trying to figure out why my binoculars were not useable in any reasonable sense of the word!
Edited by Masonry00, 29 July 2022 - 05:24 PM.
