There has been a discussion over in the refractor's topic ( __HERE__ ) about a rather unique 80mm f/10 refractor that is made by Long Perng that has a doublet with Ohara FPL-53 and Lanthanum glass. It's sold as an ED scope but given the quality glass and the rather long f/10 focal ratio it probably performs very similarly to most triplet APOs. In any case, someone who recently purchased this scope (as a rebranded StellaMira) was desiring to test the optics and thus I subsequently provided a list of close double stars ( __HERE__ ) that would be favorably placed for observation over the next month or two.
One of those stars, STF1932, peaked my own interest and on Sunday night I had a brief opportunity during late dusk to image this double star using a Celestron C90 Maksutov-Cassegrain spotting scope and a ZWO ASI178MM camera.
STF1932 is a true physical double that was first cataloged by Friedrich Georg Wilhelm von Struve in 1830 and which currently has a separation of 1.6 arc seconds. More interesting, however, is that this double consists of nearly equal 7th magnitude stars that during the month of June and early July pass very high overhead for many observers in the mid-northern latitudes (the double is located in in the constellation Corona Borealis). Thus, given these characteristic this pair of stars is a good candidate for testing the resolving power of small telescopes (at least for the next month or so). The 1.6" separation is just about the same as Dawes' limit for a 72mm refractor, but it should still provide something of a challenge for 80mm refractors and 90mm Maks.
Here is the link to the Stelle Doppie (Washington Double Star Catalog database) web page on STF1932:
https://www.stelledo...?iddoppia=62338
It looks like the A component of this double MAY itself be a double with a separation of just 0.3".
STF1932 was also the double star of the month ( __HERE__ , June 2018) on the The Webb Deep-Sky Society website.
As for my contribution, I had good seeing and managed to image this double in RGB before San Diego's "June Gloom" marine layer arrived to end my night. Image capture was done in SharpCap Pro with image processing in AutoStakkert!, PixInsight, and Photoshop CC2022. I took five hundred subs for each color and then allowed AutoStakkert! to select the best 200 to produce each RGB channel. I didn't have time to refocus between filters (the clouds were very threatening), but I think that didn't matter as the C90 has good color correction and it seems that the ZWO RGB filters were close enough to being parfocal.
Unfortunately, I wasn't given time to take a reference image that would have allowed me to determine the actual image scale, but I expect that it was close to 0.4 arc seconds per pixel. In any case, north is up in this image.
So, below is my image of STF1932 as taken with a Celestron C90 and a ZWO ASI178MM camera.
Comments and criticisms (C&C) welcomed and thanks for looking.
Edited by james7ca, 06 June 2022 - 08:31 AM.
