[NOTE ADDED: This problem was NOT what is seemed to be, and to avoid giving PixInsight a bad name, the moderator has allowed me to add this comment.
The problem does go away if you turn Local Normalization off, but it also goes away if you set Local Normalization to build the reference frame by
integrating the best frames, which is supposed to be its default. Under UNCOMMON circumstances, a different default from an earlier version can be left
behind, causing the problem reported here. Read on...]
In at least the last 2 versions of PixInsight's WeightedBatchPreprocessing script [EDIT: The latest versions, including today's], the Local Normalization option has defaulted to ON. I found it was causing a problem with my pictures, and in fact that PixInsight's lead developer (Juan Conejero) recommends NOT using Local Normalization unless there is a specific problem for it to solve. [NOTE ADDED: That is not his current recommendation. Local Normalization has been improved and normally works well.] Accordingly, I am getting much better results with it OFF, and it sounds like most people will.
Here is Juan Conejero's sage advice: https://pixinsight.c...115/#post-86421 [NOTE ADDED: Not his current recommendation!]
Here is a thread I started on PixInsight Forums to discuss this, and to request that the default be changed to OFF:
https://pixinsight.c...ocessing.18652/
The problem I experienced is that low-level noise and color non-uniformity in the sky background gets turned into dramatic colored patches if Local Normalization is on. Example below.
This was taken with a Nikon D5500 and C8 EdgeHD with f/7 reducer. For a long time I thought I was battling the Nikon lossy compression discussed here:
https://www.cloudyni...ncentric-rings/
My sky background level and flats are both well below 2100 ADU, the level at which lossy compression supposedly starts on this camera (they are in fact both a bit below 1000 ADU). Nonetheless, it's possible this is the cause of the slight discoloration shown in the upper image. What I know is that Local Normalization makes it much worse.
Sage insights would be welcomed!
Moderator's Note: I have edited this post at the request of Michael to reflect the findings discovered throughout this thread. The edits, all written by Michael, are added inline above. I have BOLDED the "NOTE ADDED" text indicating where these edits were inserted. The edited text is surrounded by [].
Edited by jonnybravo0311, 09 June 2022 - 09:47 PM.
OP request to correct some statements
