The question of whether the secondaries of non ACF scts have always been left spherical or had their figures tweaked or were aspherised to remove coma hasn't been settled and is still of interest if recent posts are anything to go by.
Their figures could be tested by interference with a test plate of matching curvature or by Hindle sphere but these are complicated to make and there are almost no accounts with photos that I've seen. Robert Piekel has a few that are ambiguous.
A non null Gaviola type test can be easily set with the help of an f4 objective and a beamsplitter cube (eg mine from Surplus Shed cost $25).
This simple test sets out to detect significant asphericity in the secondary, not to measure it accurately. I should think this could be done with a Bath interferometer in monochromatic light and DFTFringe. Perhaps also with Maciek's Ronchi software.
I recently came by a 1980s C8 and a decent Ronchi grating and so decided to compare its secondary's figure with those from a Dynamax DX-8 and 2003 8'' Meade.
The testing set up is reproduced in post 73 above, this time using a good quality Dynamax finder objective of 2'' aperture and 7.85'' f.l. Its longer conjugate is reduced from infinity to around 28'' such that its shorter conjugate is coincident with the centre of curvature of the secondary being tested.
The rays from the light source are returned after reflection off the secondary or, in the alternative configuration with the secondary removed, after reflection off the plane placed at the secondary's CoC.
In the setup, the testing objective shows considerable under-correction that is common to both configurations and so any difference detected must be down to asphericty of the 2ndry.
The background under-correction will vary with the curvature of the 2ndry being tested.
First up the DX-8. RoC is 265mm. Long conjugate=711mm
objective alone
with secondary
Looks the same to me other than the grating position being marginally different.
David
Edited by davidc135, 16 September 2023 - 07:12 PM.
