MarMax: That's a great graphic. I can't believe the cameras are that different. Amazing.
Is that from a web-tool?
The fov with the 294 would be vast with the small piggy back frac, but that graphic also shows the FOV would be pretty good even with the straight 925, even without reducer for a lot of objects I want to look at. Would probably be even be better with the 925 for small DSO, than with a piggy back scope.
Alphatriple: I can see the big FOV would help locate objects. With my aim to do dual visual/EAA the EP view should help overcome problems finding the target, I would hope.
Schoolmaster: Excellent point that. With the 925 and an 80mm it would cover both for large objects and the small ones. I think that's convinced me I don't need to go over 80mm.
20 Second Subs?
So that just leaves me wondering whether with a reasonable 80mm Frac at say around F6 if I would end up with problems with the limited 20second subs the CPC will allow.
And with the cam swapped to the 925 for smaller DSO objects? I suppose a celestron reducer would be essential for those. Would it be enough though with only 20seconds maximum exposure?
Here is the linky to Astronomy Tools. You will use it a lot.
