Processing using Siril and Photoshop of a fairly recently discovered object
DSO Astrophotography Imaging Software
6 replies to this topic
#1 Martin Schoenmaker
Martin Schoenmaker
  • Loc: Netherlands
Posted 22 June 2022 - 03:13 PM
I have been working on a Hubble Palette image of the Crescent nebula. I was however after an object which lies very close to this nebula, but was only discovered in 2008. Fairly recently in my book.
I was very stoked to see it already in the Hydrogen-alpha data after stacking. But I knew from other images that this object should shine blue, so I had my hopes on [OIII].
Using my William Optics GT81 telescope, the Flat6A III 0.8x reducer, the ASI2600MM Pro camera (mono) and a filterwheel with S, H and O filters I got to this result.
In order to show how I reached this result I screenrecorded the processing. With all the explanatory talking it turned out to be pretty long. So I decided to split it in two parts and share it on YouTube.
I am certain that I did things in ways that could be improved. Please feel free to post your feedback.
By the way, yes I know I should have shot darks... ;-)
Part 1: Using Siril to stack everything.
https://www.youtube....h?v=lihYh83bfJY
Part 2: Using Starnet++ to remove the stars and Photoshop to put everything together (and re-add the stars).
https://www.youtube....h?v=BBy7VDx6xjw
  • mikewayne3, Ljubo, bobzeq25 and 9 others like this
#2 Martin Schoenmaker
Martin Schoenmaker
  • Loc: Netherlands
Posted 22 June 2022 - 03:14 PM
I should've added that it was about the Soap Bubble nebula, which is to the left of the Crescent. See this crop:
  • Ljubo, unitron_man, Skysmacker and 3 others like this
#3 Skysmacker
Skysmacker
  • Loc: Bay Area CA
Posted 22 June 2022 - 03:32 PM
Fantastic work! That is amazing!
I am about to begin my foray into narrowband. I also use SiriL so I really appreciate the videos in this post!
Thanks for sharing!
  • Martin Schoenmaker likes this
#4 SimRacingGarage
SimRacingGarage
  • Loc: Virginia
Posted 22 June 2022 - 05:34 PM
Awesome videos! I have saved them in my YouTube Astrophotography play list. Just getting started, so this helps a lot.
#5 Martin Schoenmaker
Martin Schoenmaker
  • Loc: Netherlands
Posted 23 June 2022 - 03:54 AM
Two things I would like to improve in my image are the noise levels and the stars.
I think the first needs to be solved by adding more data. But also I was reminded that by adding proper darks to the processing I would be able to lessen the noise.
The stars I'd like to fix by also shooting some RGB data on this object. I can then extract the RGB stars and paste them into this narrowband data.
#6 Oort Cloud
Oort Cloud
  • Loc: New Jersey, USA
Posted 23 June 2022 - 01:06 PM
Darks are a waste of time with that sensor if you dither, since it doesn't have any amp glow. Others will surely disagree on this, but I am not the only one using a 5xx sensor that stopped using darks for this reason.
#7 Martin Schoenmaker
Martin Schoenmaker
  • Loc: Netherlands
Posted 24 June 2022 - 02:48 PM
That was my firm believe as well. I am using dithering (of course). Anyway, this was shot in astro-twilight mostly (no astro-dark for some time over here) and not that many subs. I contribute the noise mostly to that.
Also tagged with one or more of these keywords: DSO, Astrophotography, Imaging, Software
