great images !
If I may ask: how many frames did you select/stack ?
Thanks! In this case I stacked 400 frames. More typically I'll stack 100-200. I'll usually take 1500-2000 frames, use PIPP to down-select the sharpest 400 into a new SER file, and then use Autostakkert to process these, typically selecting the sharpest 100-200 for stacking. Generally,I look at how the resolution falls of in Autostakkert's plot that it shows and usually pick a couple values of number of frames/percentage to stack. I'll then stack in autostakkert and sharpen in registaxx and visually see which set I think gives the better image. Generally speaking, though, I use 100-200. Just that yesterday the falloff in seeing was more gradual than usual so I stacked more frames.
Edited by hamers, 24 June 2022 - 12:57 PM.
