Posted 29 June 2022 - 10:42 AM
The SW 100ED plus the Stellarvue M2C would just come under the 2k mark (ignoring taxes), and would be a very good setup, definitely worth the extra cost over an 80mm for your only scope.
Another option is to change scopes and go with the very well respected Astro tech AT102ED, runs $650. Doesn’t include a diagonal, finder, or eyepieces though, which would cut into the savings a bit (can go used on those easily enough however).
I would say definitely spring for a 100mm class scope if it will be your only one, 80mm are good for certain things, but not a great do it all scope.
As always though with someone’s first scope I always have to recommend you consider the classic first scope option nearly everyone recommends (for good reason), an 8”-10” dob. Lots of reasons to like refractors (I own a bunch), so I don’t want to talk you out of one. Just another (and cheaper) option to consider.
