I had a M2C for a while and I think it might work if you get the balance just right, but I never would have mounted my AP130GTX on it, which isn't that much bigger than a TSA120 appears to be (the 130GTX actually has a shorter focal length). It would probably be adequate for low to medium powers, but I doubt it would work well at high power due to vibration. Changing eyepieces with that much weight up front would also be a challenge, no matter how much tension you put on the altitude axis. I'd have similar concerns about using a DM-4, it too is going to be at its limit with the TSA, but its design means it might handle eyepiece changes better.
Since the TSA can take high magnification with ease, I'd want a sturdy mount with slow-motion controls or very smooth movements. Hence the recommendation for the AZ100 or used FTX, probably on a T-Pod or similar to minimize weight. I'm sure there other mounts out there too, but I'm sticking to ones I've actually used.
Like others have said, I think the cheaper class of mounts aren't going to be an option if you want to maximize utility with this scope. The M2C and other mounts like it were designed for smaller instruments, even if their specs indicate that they can theoretically hold the TSA.
Edited by weis14, 28 June 2022 - 07:55 PM.
