First narrowband image with the new rig. The Pelican Nebula in SHO.
https://www.astrobin.com/6gjz91/0/
The CDK14 with the 0.66x reducer is very well suited for narrowband nebula imaging. The FOV is about 1.5 degrees with the full frame sensor, it was a bit too much and I had to crop a bit of the frame for my taste.
Being almost 50 degrees latitude north meant there no astronomically dark nights (not even 30 minutes) at this date, but I finally finished finetuning the setup and wanted to get some data regardless. It turned out better than I expected.
The combination of aperture, fast focal ratio, very narrow bandpass and the very low noise QHY600M meant a decent amount of data could be captured despite the conditions and Bortle 6 suburban sky.
The image scale is 0.465"/pixel and was downsampled to reduce the image size showing the "big picture".
Integration:14h
Bortle Dark-Sky Scale:6.00
Pixel scale: 0.871 arcsec/pixel
Edited by Rouzbeh, 28 June 2022 - 08:34 PM.
