I want to use my Celestron nexstar évolution mount and its starsense Celestron with a skywatcher evo 72ED or 62ED.
Can i mount these refractors on this mount and the starsense on them or do i need some extra stuff ?
thanks
skywatcher refractors on Celestron nexstar évolution mount
#1
Posted 30 June 2022 - 08:03 AM
#2
Posted 30 June 2022 - 08:29 AM
Edited by deansjc, 30 June 2022 - 08:30 AM.
#3
Posted 30 June 2022 - 08:37 AM
You'll either have to put it on a wedge or adjust the slew limits, but yes, it'll work with the right adapters and rail.
#4
Posted 30 June 2022 - 01:48 PM
Here are some pictures of how I mount my EvoStar 72 to the 8SE mount. I am pretty sure your mount is similar in this regard.
I am currently using an extra long adapter (Vixen height extender). You only need a short one as shown in the picture below. The dimensions need to be close, but not exact given the clamping mechanism on the Celestron mounts.
Included here are some pictures of the small adapter and how things look assembled. You may need to rotate the tube so that the focus knobs are accessible and do not contact the mount itself. You can move the OTA forward and back in its clamp mechanism to suit, but do check on balance. A longer adapter allows the addition of counterweights if needed. These mounts are never is easy to balance however for visual, it is a non-issue and my balance allows for AP but only when guiding (on a wedge).
You can see that I have added an additional platform that allows for accessories. Looks like a lot, but isn't really. The mount IS NOT overloaded. Wood does not flex as much as people say. It works well. I can expose for 4 minutes when conditions permit.
Happy to answer any questions.
John
#5
Posted 03 July 2022 - 02:27 AM
thanks
Very interesting and instructive photos unfortunately I am not at all a handyman.
Nevertheless I understood that I can mount directly the 72ed on the mount
but balancing will be difficult and the focuser knobs will hurt the mount in some position
#6
Posted 03 July 2022 - 08:55 AM
thanks
Yes, if you're using the mount in alt-az mode, it's important you set slew limits to not crash into the mount. I can't tell you an exact value, but if I remember correctly the default value is 90 degrees, which is straight up.
Balancing isn't so much an issue, the Nexstar SE and Evolution mounts are extremely forgiving.
Edited by firemachine69, 03 July 2022 - 08:56 AM.
